Special part for sale on ebay
joefarmer
Unread post by joefarmer » Thu Nov 09, 2017 3:45 pm
Came across this today while browsing ebay... thought it was worth sharing.
Joe Farmer
64 Corvair Monza 900
Follow along at:
https://www.corvairforum.com/forum/view ... 52&t=12693
Gregory_Miller
Re: Special part for sale on ebay
Unread post by Gregory_Miller » Thu Nov 09, 2017 4:02 pm
Happens all the time. There's LOTS of thermostats that fit the Corvair apparently.
thewolfe
Unread post by thewolfe » Thu Nov 09, 2017 4:47 pm
Adding -fits to your ebay corvair search will filter out these and the thousands of other non corvair parts on there that are listed as fitting a corvair.
Nate Wolfe
65 corsa 180
lostboy
Unread post by lostboy » Thu Nov 09, 2017 7:31 pm
Yeah. Every time I see that I think to myself, someone somewhere is professionally trolling the Corvair community.
-Steve
Bob Roegge
Unread post by Bob Roegge » Fri Nov 10, 2017 12:24 pm
I did some extensive research and can verify that it will fit in the glovebox of my 64 Spyder.
skipvair
Unread post by skipvair » Fri Nov 10, 2017 5:18 pm
joefarmer wrote:Came across this today while browsing ebay... thought it was worth sharing.
That’s the one in mine.
caraholic4life
Unread post by caraholic4life » Sat Nov 11, 2017 9:15 am
Actually, the ad is sort of accurate......
All you need to do is install all the other needed components into your Corvair in order for it to "Fit" as advertised.
My old Kelmark conversion had one of those thermostat's in it an it worked out just fine.
I always enjoyed screwing with uneducated parts counter people when buying parts for my car.
I would go in and ask for a part that (at the time) was universal for virtually all small block Chevrolet motors like a distributor cap, points, rotor, or even a thermostat. These would have been items that any competent auto parts person would be able to pull from the shelves without needing to look it up.
When the uneducated incompetent moron would ask me "Uh, what kind of car is it in?" or something along those lines, I would respond that it is in a 1966 Chevrolet Corvair and watch them attempt to look it up. I would eventually give the "Expert" an application that their feeble mind could look up in order to look up the item I needed. Yes, it did get frustrating at times which is why I started screwing with them to begin with.
These days I often supply a valid part number for the "Expert" to begin with as the majority of them are not getting any brighter as time goes on. :my02:
Maybe I am getting less patient with auto parts people as I get older. Especially since I worked in the industry for many years and held an ASE Certification for Automotive Parts until I let it lapse a few years ago. :think:
Unread post by terribleted » Sat Nov 11, 2017 11:06 am
LOL I used to have a phone book listing for my business. The listing was Corvair Repair. Periodically a radiator shop would call Corvair Repair to try to sell me radiators for Corvairs:)
skipvair
Unread post by skipvair » Sat Nov 11, 2017 8:08 pm
Did you buy them?
Unread post by terribleted » Sat Nov 11, 2017 9:21 pm
Did you buy them?
LOL I think not:)
Nickshu
Unread post by Nickshu » Sun Nov 12, 2017 8:00 am
I need one of those!!!
Nick_______________________________
1964 Monza Spyder Convertible #435 - Rotisserie restored
Check out my restoration thread here: http://corvaircenter.com/phorum/read.php?1,681169
Recreational Mechanic/CORSA Member/COG Supporting Member/Navy Veteran
CorvairCon65
Unread post by CorvairCon65 » Mon Nov 13, 2017 6:35 am
Same for air-cooled DAFs, there are radiator stop-leak products and the like on eBay and the like which apparently will work for my cars...
