Passenger side outside mirror location '65 to '69.
bobg1951chevy
Unread post by bobg1951chevy » Tue Sep 12, 2017 10:58 pm
1965 to 1969 PASSENGER OUTSIDE MIRROR LOCATION.
I now have a N.O.S. Right mirror, but no template came with the mirror.
For those of you who have a factory right outside mirror, how far is the distance from the leading edge of the mirror base to the door / fender gap ?
Thanks.
Bob G., Hendersonville, NC.
1951 Chevy Styleline Deluxe 2 door sedan. 6/2000.
1951 Chevy Styleline Deluxe Sport Coupe. 5/2014.
1969 Corvair 500 Coupe # 2671. 7/2017.
Folgers57
Re: Passenger side outside mirror location '65 to '69.
Unread post by Folgers57 » Thu Sep 14, 2017 2:33 pm
Folgers57
Unread post by Folgers57 » Thu Sep 14, 2017 2:34 pm
Hope this helps
Folgers57
From a 65 Vert Monza 110
bobg1951chevy
Unread post by bobg1951chevy » Thu Sep 14, 2017 10:34 pm
Hope this helps
Yes, your pic does help. Thank you.
In that position, is your visibility good from drivers seat ?
I do see you have good clearance from vent glass.
skipvair
Unread post by skipvair » Fri Sep 15, 2017 6:01 pm
It looks identical to my 65. Visibility was terrible until I put seat track extenders on it pushing seat back. It still isn't great.
Spike65
Unread post by Spike65 » Sat Sep 16, 2017 12:47 pm
Typically left and right side mirrors have identical mounting points as does my 65 Corsa convert
bobg1951chevy
Unread post by bobg1951chevy » Sat Sep 16, 2017 9:32 pm
Thanks for your info. :tu:
bobg1951chevy
Unread post by bobg1951chevy » Sat Sep 16, 2017 9:34 pm
I understood the right mirror was set further FORWARD, but that would interfere with the wing window operation.
Folgers57
Unread post by Folgers57 » Sun Sep 17, 2017 7:13 am
Works good for me, haven't had any issues.
bobg1951chevy
Unread post by bobg1951chevy » Sun Sep 24, 2017 12:17 am
Thanks, Folgers57.
Unread post by bbodie52 » Sun Sep 24, 2017 5:45 am
Image :chevy:
The attached 1965 Corvair Assembly Manual - OUTSIDE REAR VIEW MIRROR section describes the left-side installation for both the regular and remote control mirror on the 1965 Corvair. I did not find anything for the passenger side, but the pictures would seem to show an identical location in relation with the window wing frame as a reference.
1965 Corvair Assembly Manual - OUTSIDE REAR VIEW MIRROR.pdf
(726.69 KiB) Downloaded 4 times
bobg1951chevy
Unread post by bobg1951chevy » Wed Sep 27, 2017 9:31 pm
Thanks Brad, info is appreciated.
