1964 700 4 door, never owned one before, I think that this one is worth saving, I've done paint body work for 20 years and I have only done a few corvair, but that's been 15 years or so since I changed carriers. Looking forward to fixing this one up. I have learned quite a bit of information from reading some of the post, and appreciate any advice.
Sent from my SAMSUNG-SM-G891A using Corvair Forum mobile app
Barn find in Oklahoma
Re: Barn find in Oklahoma
Welcome to the Corvair Forum!
If the body is solid on your "barn find", and you possess the all too rare skills in body repair, it would seem that you are way ahead of the game. The 1964 Corvair was the product of five model years of refinement and improvements. GM took the swing axle rear suspension just about as far as they could — ultimately replacing it with a copy of the rear suspension from the Corvette of that period in 1965. The addition of a standard front stabilizer bar and rear transverse leaf spring (along with new coil spring rates) did a pretty good job of stabilizing and controlling the swing axle suspension design. The engine was increased to 164 CI by lengthening the crankshaft stroke, which increased horsepower and torque for improved performance. The cooling fan was redesigned and manufactured from magnesium to reduce the weight and "flywheel effects" that would place a lot of stress on the Corvair fan belt as the early design steel cooling fan constantly fought engine speed changes, with the fan belt placed in the middle of a "tug-of-war" between the cooling fan and the crankshaft pulley. The magnesium blower and belt guides did a lot for improving fan belt reliability. Corvairs used to have a reputation for leaking oil from the pushrod tube seals. The production of O rings made from VITON made a huge difference, as the new material tolerated the high engine heat found an air cooled engines much better than the earlier materials.
Maintenance of the Corvair engine is something of a crossover between automotive engines and motorcycle engines. The use of multiple carburetors and an air cooled aluminum engine might seem familiar to a motorcycle mechanic, but takes the conventional automobile mechanic into uncertain territory. If you follow the shop manual instructions and make use of a torque wrench and anti-seize compound to help protect the soft threads found in the aluminum engine, you shouldn't have any problem. If you have questions, websites like the Corvair Forum and local CORSA club chapters go a long way in helping you to accomplish mechanical tasks on your Corvair.
The mechanical side of working on Corvair engines, transaxles, suspension and brakes are relatively easy to learn. Replacement components from sources like Clark's Corvair Parts are plentiful, as are excellent interior upholstery and carpeting reproductions to help you with interior restoration, as needed.
viewtopic.php?f=225&t=6007
Assuming that you live in Oklahoma, there are two CORSA club chapters in that state…
Central Oklahoma Corvair Association
Midwest City/Oklahoma City Area http://www.cokcca.org/
Green Country Corvair Group
Tulsa Area Corvair Club http://tulsacorvair.com/dokuwiki/doku.php
I would like to encourage you to expand on your initial post and tell us more about yourself. If you can describe your personal assessment of your mechanical skills and abilities, that would help a lot. Members of the Corvair Forum love to be helpful in assisting other Corvair owners with technical support and advice, but it helps a lot if we have some understanding of your technical background and mechanical abilities, Corvair-related knowledge, etc. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Knowing your location is also useful, because knowing where you live can sometimes suggest possibilities.
First I would like to say thanks, I live in Norman Oklahoma, like I stated in my first post I've done paint and body work for over 20 years, building numerous cars over the years, several of which were in car shows. I have been into cars since I was a youngster, shade tree mechanic you could say. Im excited to start on the corvair, body is solid with minimal rust (3 small spots in floor panels, still cleaning it up so not sure just how far I need to go with but it's all there and the price was just right ( $80 ) again thanks for the info, it's always good to get several opinions on whatever I'm about to take on. Thanks again, looking forward to exchanging information.
Welcome from Central Oklahoma Corvair Associationdudedad64 wrote:First I would like to say thanks, I live in Norman Oklahoma, like I stated in my first post I've done paint and body work for over 20 years, building numerous cars over the years, several of which were in car shows. I have been into cars since I was a youngster, shade tree mechanic you could say. Im excited to start on the corvair, body is solid with minimal rust (3 small spots in floor panels, still cleaning it up so not sure just how far I need to go with but it's all there and the price was just right ( $80 ) again thanks for the info, it's always good to get several opinions on whatever I'm about to take on. Thanks again, looking forward to exchanging information.
Welcome. nice find. Do us proud!
Ed Stevenson
Ed Stevenson
