Lifters noise at start up
TheCommish
Unread post by TheCommish » Thu Aug 24, 2017 9:19 am
Since I put Diesel 15w40 in my 63, my lifters are real noisy, can I add a lifter additive, or accept this as a "Corvair" thing where oil drains out.
lostboy
Re: Lifters noise at start up
Unread post by lostboy » Thu Aug 24, 2017 9:46 am
TheCommish wrote:Since I put Diesel 15w40 in my 63, my lifters are real noisy, can I add a lifter additive, or accept this as a "Corvair" thing where oil drains out.
Mine does it sporadically. Time it sits doesn't seem to matter. Temperature doesn't either.
-Steve
notched
Unread post by notched » Thu Aug 24, 2017 10:00 am
The correct weight oil is 10W30. Your oil is too think. Secondly many Corvairs will tap on initial start up if the lifters bleed down. What I typically do if mine sits for a long time is to crank the engine until the oil light goes out and then set the choke and fire it off. They never tap when doing this.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Unread post by terribleted » Thu Aug 24, 2017 10:14 am
15w 40 would if anything be a little thick not thin. Spec is SAE 30 single weight.
How often is the car started? if it is making lifter noise on every start and is driven every day bad lifter adjustment or other valve train issues are likely. If they tap for a minute or 2 after the car has not been run for a few days or more this is more toward normal and may not need to be addressed at all. IF everything is adjusted correctly and not worn most cars will not tap on start unless they have been sitting for quite a while (perhaps a month or more). Some engines will not tap after sitting a very long time (think year or more) while others might tap a little after only a few days.
If they are noisy after the car is warm you have a problem you need to go fix.
notched
Unread post by notched » Thu Aug 24, 2017 10:16 am
Actually Ted, correct weight as specified in the owners manual and with Richard Widman on FB and the other message board is 10W30.
1966 Corsa turbo
notched
Unread post by notched » Thu Aug 24, 2017 10:22 am
Here is something from oil engineer Richard Widman
1966 Corsa turbo
TheCommish
Unread post by TheCommish » Thu Aug 24, 2017 10:45 am
Florida heat is 90f-95f
Need Zink in Oil thats why Diesel 15w40
notched
Unread post by notched » Thu Aug 24, 2017 10:53 am
Dave Motohead and I just talked about this. He lives out in the desert of California and runs 10W30 and it was just 112 there. Thick oil does more harm than good. Just saying.
1966 Corsa turbo
lostboy
Unread post by lostboy » Thu Aug 24, 2017 12:06 pm
TheCommish wrote:Florida heat is 90f-95f
Rotella? I run T4 10w-30 and some Lucas oil additive at every oil change. I'll admit the startup noise did get significantly less with the Lucas.
-Steve
Unread post by terribleted » Thu Aug 24, 2017 2:05 pm
Actually the early model shop manuals specify SAE 30 or SAE 10w-30 if you prefer a multi weight. The oil weight is not particularly relevant to lifter noise. If the lifters are adjusted properly and in good condition the weight of oil is not likely to make a significant difference in lifter function unless it is way out of the ballpark. The change of oil should not have made a big difference unless perhaps some high detergent cleaned out some sludge making things operate more loosely.
The issue at hand here is the lifter noise.
AGAIN!!!! How often is the car started? How long do they make noise? Do they make noise after the engine is warm?? If it is making lifter noise on every start and is driven every day bad lifter adjustment or other valve train issues are likely. If they tap for a minute or 2 after the car has not been run for a few days or more this is more toward normal and may not need to be addressed at all. IF everything is adjusted correctly and not worn most cars will not tap on start unless they have been sitting for quite a while (perhaps a month or more). Some engines will not tap after sitting a very long time (think year or more) while others might tap a little after only a few days.
If they are noisy after the car is warm you have a problem you need to go fix for sure. If there is significant lifter noise I would suggest performing a running lifter adjustment and see if the problem is solved. A very simple process requiring only a couple new valve cover gaskets and some time.
Gearfinger
Unread post by Gearfinger » Fri Aug 25, 2017 5:55 am
The car belongs to you. Run what oil you want and pay no attention to opinions.
As a general rule, you set idling at a stop light a lot in Florida. Not so much in the desert...
64powerglide
Unread post by 64powerglide » Fri Aug 25, 2017 6:34 am
Have a look at this video.
64powerglide
Unread post by 64powerglide » Fri Aug 25, 2017 6:44 am
Watch this one too.
66corsaguy
Unread post by 66corsaguy » Sat Aug 26, 2017 12:53 am
Gearfinger wrote:The car belongs to you. Run what oil you want and pay no attention to opinions.
toytron
Unread post by toytron » Sat Aug 26, 2017 3:21 am
If you are coming to a forum are you not asking for an opinion?
I could be wrong but I think gearfinger was just joking.
Ed Stevenson
davette59
Unread post by davette59 » Sat Sep 09, 2017 5:27 pm
Mine did the same thing, the longer it was between startups, the noisier and longer the noise lasted. I put Seafoam in and the noise quieted immediately.
