Weber carb fuel line routing
skipvair
Unread post by skipvair » Sun Jul 16, 2017 10:24 am
Anybody have a photo of their routing on fuel lines when using 2 weber 3 barrels? Mine works fine but is routed from old fuel pump and crosses over fanbelt making a belt change a nightmare. I a looking to re-route to the front of the engine incorporatind a pressure regulator and gauge there, but linkage will make it tight. I would like some pics of how other people have done it.
Re: Weber carb fuel line routing
Unread post by bbodie52 » Sun Jul 16, 2017 1:29 pm
Corvair1 wrote:Thu Mar 21, 2013 4:53 pm
This is the filter setup I have. It has interchangeable elements and it looks a little nicer than the plastic inline ones which look a little cheesy...
The fuel routing set up pictured above with a layout designed by the late Herb Simons of Ontario Canada (who passed away on December 7, 2013). Herb always seem to take innovative approaches with his Corvair and was not afraid to experiment. By mounting a fuel distribution block on the firewall at the front of the engine compartment, fuel lines can be easily routed to carburetors or fuel injection systems on either side of the engine without crossing over the fan belt path. Accessories such as in-line fuel filters with interchangeable elements, a fuel pressure regulator, and even a mechanical fuel pressure gauge can all be mounted on a multiple outlet fuel distribution block. Fuel lines leading from the fuel block to the carburetors or fuel injection bodies can be steel tubing, rubber fuel lines, or exotic braided aircraft style fuel lines connected with AN fittings. The fuel block can be connected to a forward-mounted electric fuel pump, or can be routed around the perimeter of the engine compartment for connection to the mechanical fuel pump.
The late-model Corvair pictured below utilizes the suggested firewall mount for distribution to Weber three barrel carburetors using braided aircraft-style fuel lines…
skipvair
Unread post by skipvair » Sun Jul 16, 2017 5:13 pm
Thanks for the suggestions and pictures
skipvair
Unread post by skipvair » Sun Jul 16, 2017 5:24 pm
skipvair
Unread post by skipvair » Sun Jul 16, 2017 5:25 pm
That is my present set up. Works well, but changing a fanbelt would involve removing fuel lines.
lostboy
Unread post by lostboy » Wed Jul 19, 2017 3:52 am
I've been using a braided stainless steel swagelok line as the master feed to the stock splitter. Has been working very well. I like that swagelok does not use those blue an fittings.
-Steve
