Size of gas line EM
TheCommish
Size of gas line EM
Post by TheCommish »
I want to buy a piece of Rubber gas line from Steel line in tunnel to Gas Tank, what is the Inner Diameter?
Re: Size of gas line EM
The metal line from the tank to the rear and the short piece from the rubber joiner above the left rear wheel to the pump are all 5/16" diameter (so 5/16" ID hose). The lines from the pump to the carbs are 1/4"
Make sure you buy fuel hose approved for ethanol blends (yes the cheap non-ethanol tolerant fuel hose is still sold).
A buddy had a hose turn to mush. Nothing on the package about ethanol, but AT THE WEBSITE --- "This hose is not for use with ethanol fuels" - grrrrrr.
Gates BARRICADE low pressure fuel injection hose is approved for all automotive fuels types in the U.S.A. You can use the Gate BARRICADE high pressure fuel injection hose, but it costs more and is not required, but if the low pressure is not available it works fine.
It's sold in a number of sizes at automotive parts stores.
Nothing more annoying than a gooey fuel hose.
