Axle Dipstick
Mr.G
Axle Dipstick
Unread post by Mr.G » Fri May 19, 2017 10:12 am
64 Spyder. I need to know how long the axle Dipstick should be. I think someone put an oil dipstick in my car causing me to over fill the axle and have it all leak out within a day. The dipstick in there now is the exact length as the oil dipstick. I had filled it through the dipstick tube, today the dipstick read empty so I got under the car and removed the plug and it started to leak out so it is full. I was thinking I had a major leak when I got the car last year and now am wondering if the leak was caused by the axle being over filled. Your Thoughts ? Thanks
64powerglide
Re: Axle Dipstick
Unread post by 64powerglide » Fri May 19, 2017 2:15 pm
My 64 with a powerglide is 19 inches with a slight curve. From the tip to the full mark is 2 & 1/2 inches.
Mr.G
Re: Axle Dipstick
Unread post by Mr.G » Sat May 20, 2017 6:34 am
Thanks, I have a 4 speed but I would assume they share the same axle. I also read that the 4 speed transmission and axle share the oil, strange because both have their own plug but it would make sense if when used with the powerglide the axle would be separate oil.
Mr.G
Re: Axle Dipstick
Unread post by Mr.G » Sat May 20, 2017 9:24 am
OK, so the one in there now is 14 1/2, same as the oil dipstick. I made one 19" and now it shows full ! I hope that this was the cause of the leak.
