WHAT IS THIS PART?
WHAT IS THIS PART?
i REMOVED MY MOTOR AND REMOVED CLUTCH DISK. ALSO i REPLACED DRIVE SHAFT SEALS. THIS PART WAS LAYING ON THE FLOOR. dOES IT BELONG IN THERE SOMEWHERE?
Re: WHAT IS THIS PART?
I can only assume you tried to add an attachment & it didn't work. Click on ATTACHMENTS then ADD FILES, then select the file then SUBMIT.
- Jeffrey Lee.jpg (108.66 KiB) Viewed 277 times
