leaky spot...
leaky spot...
Ok I have pulled the carb and the turbo off to rebuild on my 64 spyder vert. Those being delt with Im not sure where to start on an oil leak that I have noticed? I am guessing valve cover? or the turbo was leaking? I really am not to sure? I know the turbo had oil flow and was blowing bye and burning pretty badly so I guess that could be the leaky spot. Also it was pretty steadly dripping under the turbo side. But it was running down the engine shelf so I couldn't really pin point it...
Re: leaky spot...
On mine the turbo drain return line in the head is a little loose, so it weeps there...
Re: leaky spot...
Thanks guess I will check that when i get it to my buddies shop...
