OK mine did not have one of these when I got it (C8450) diff. dip stick tube GROMMET, does the rubber point up and toward
the rear on the motor side of the firewall or does it go on the front side of the firewall pointed down toward the diff.?
THANKS Jimbo
Axle Check Tube GROMMET
Re: Axle Check Tube GROMMET
The rubber boot part goes forward of the firewall down toward the diff, so all you have on the engine side is the strip of rubber around your oval hole.
yep had to be that way after looking at it more, THANKS Jimbo
