I have been working on the Corsa on and off every now and then. Here is a bit on my Half Shaft Restoration with new HD U-joints. Part 1 is the removal of the U-Joints and clean up of the shaft.
Part 2 will be U-Joint installation. Link to Part 2: viewtopic.php?f=55&t=2149
My 7 year old son is the photographer on this project! We are both learning a lot and having a blast!
U-Joint / Half Shaft Restoration Part 1: Corsa GT Project
- I like to soak the shafts with penetrating lube the day before I try to remove the shafts and U-joints. Mark the shafts before you remove them. PT (Passenger side Transaxle), DT (Drivers side). After you get the shaft out you can use a punch to permanently mark each shaft. Why? Go to part 2 for the U-joint install for an explanation.
- Using lots of lube, press the old U-Joint 90% of the way out. I don't like to press it all the way out as it still won't make enough room for the joint to come out of the shaft and you will have to restart the cap when you press it the other way. It can get troublesome sometimes. Don't worry if it comes all the way out though, just restart it again after you get the cap out. You can do this with a vise if you don't have a press.
- I clean the parts first with a degreaser to get the big crud off. This helps make my blasting medium last longer. Then I glass bead blast the part (shaft) making sure to get into the small areas such as the clip grooves. Once this is done, I debur the piece with a file to remove any nicks, scratches or welding splash.
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
Re: U-Joint / Half Shaft Restoration Part 1: Corsa GT Projec
oooh, thats purrrty
Re: U-Joint / Half Shaft Restoration Part 1: Corsa GT Project
