How to not starve whilst cornering
cvair4life
Post by cvair4life »
I'm a mild city driver..... :rallye: :burnout: .... anyway the car starves while I'm cornering. I assume this is because the gash sloshes over in the bowl and pushes the float up to close the fuel inlet valve on one of the two carbs or maybe both. :think:
Is there a solution for this on the stock Carter's?
1966 Corsa Coupe
Re: How to not starve whilst cornering
IIRC, I thought that was the reason they made the carb rotation kits, right?
cvair4life wrote:"I'm a mild city driver....."
my A$$ :rolling:
anyway look here.
http://autoxer.skiblack.com/carbs.html
martyscarr
Post by martyscarr »
Sure, the solution is EFI :evil:
You do mean Rochester carbs, don't you? Turn cutout can be helped with vent tube extensions, next step is main jet relocation. Lots of info here:http://autoxer.skiblack.com/carbs.html
Marty Scarr
cvair4life
my A$$ :rolling:
WHAT!!! :dontknow: :evil:
1966 Corsa Coupe
cvair4life
Thanks guys I'll read up on it.
1966 Corsa Coupe
66corsa57isetta
Post by 66corsa57isetta »
if you grab a quick bite to eat before driving you wont starve in the corvers. its an easy solution.... much cheaper then EFI
hehehehe
-Michael Barney
Ft. Wayne, Indiana
-1966 Corsa Coupe, 140, 4 speed (sold but still in good hands!!)
-1957 BMW isetta 300 bubble window, 13 HP, 4 speed BEAST!!
I heard that hunger can also be a problem while doing quarter mile runs in Ultravans with powerglides..... :rolling:
cvair4life
66corsa57isetta wrote:if you grab a quick bite to eat before driving you wont starve in the corvers. its an easy solution.... much cheaper then EFI
hehehehe
LMAO.... that's funny. Burger in hand... hand on wheel... WHO THE HELL IS SHIFTING into 3rd? Solution... more rpm... set burger down... shift... more rpm... eat burger :)
1966 Corsa Coupe
