tire pressures
64vert
tire pressures
Post by 64vert »
for 13" 185/80...24 lbs in the back 20 lbs in the front?
omaha, ne
corvair midwest
CORSA
reidmier
Re: tire pressures
Post by reidmier »
I like to maintain about 8-10 pounds of difference front to back. If you're running Steel Belted Radials, try 20/28 and see how it feels. BTW... I prefer a stiffer ride, so I run 22/30 to keep the front sidewalls from flexing quite so much.
Reid M.
Washington, UT.
'65 Monza 110 PG
http://www.hacoa.org/
http://www.vegasvairs.com/
Re: tire pressures
yup 8-10 lbs difference.. Normal PSI in the rear and lighten it up by 8-10 up front.
64vert
Re: tire pressures
Post by 64vert »
thanks guys! :tu:
omaha, ne
corvair midwest
CORSA
