Horn goes off
Horn goes off
the horn in my 1966 Coupe just went off while the car was sitting in the driveway - what could cause this - bad horn relay?
Can you tap the relay to see if it's sticking - and how to trouble this correctly? I have not looked but I believe the horn relay is mounted in the trunk.
thanks
thanks
Re: Horn goes off
The amount of electrical current drawn by the horns is far too mucch to be handled by the small switching system in the steering column. Because of this, a horn rela is used in the trunk to handle the high current drawn by the horns. The small switch contact in the steering column provides a ground connection when the horn button is pushed by the driver. This ground connection causes the horn relay in the trunk to close, which powers the horns until the driver releases the horn button.
In the above illustration, the heavy gauge 14R (14 Gauge Red) wire feeds battery voltage to the relay. When the operator presses the horn button, the thin 20 gauge black wire is grounded, which closes the relay contact and powers the horns.
If the relay has an internal short or is otherwise defective, the internal relay contacts may have closed and powered the horns. This type of fault would require replacement of the relay. It is also possible that there is a short within the steering column or somewhere along the relay ground wire that triggered the horn relay. An inspection of the wiring harness my reveal a wiring fault.
https://ssl.corvair.com/user-cgi/catalo ... ow_page=88
Part number C1167: HORN RELAY
Weight: 0 lbs 6 oz
Catalog Page(s): 88
Price: $ 15.65
Weight: 0 lbs 6 oz
Catalog Page(s): 88
Price: $ 15.65
- 1965 Corvair Assembly Manual - ELECTRICAL COMPONENTS, HARNESSES & SCHEMATICS.pdf
- (12.21 MiB) Downloaded 9 times
Re: Horn goes off
thanks for your input - RD
- Frank DuVal
Re: Horn goes off
When you take the horn button off to see the three screws that hold the special washer in position, the screws might be Clutch Head screws, but a small slotted screwdriver usually works to unscrew them. Pay attention take pictures/notes as to how that not-flat washer sits when you take the three screws out.
Hey look, blue background!
Horn relay check?
Question - how / what readings are you looking for when checking the horn relay with a multi meter to see if it's bad? Thanks
Re: Horn goes off
Frank - what special washer are you referring to I have no washer - just 3 brass screw that attach the part that the horn button snaps to and has a long leg that goes to the horn's plunger inside of the steering wheel hub.
I have a wood sport (GM OE PART) steering wheel on my 66 coupe.
- Frank DuVal
Re: Horn goes off
The washer down below the cup, as large as the cup with a center hole and three holes for the brass screws/insulator assembly. It is a Belleville like washer that snaps from one shape to the other in order for the contact to be made to ground the spring loaded horn terminal (located below this washer). Similar to these parts:
Re: Horn goes off
ok got it Frank. thanks for the clarification and your help - the horns seems to be working as normal now.
- American Mel
Re: Horn goes off
My first thought when a horn starts honking all by itself, is,........... Mice/Rodents.
I don't believe in ghosts.
Re: Horn goes off
In my 65 Corsa in 1975 I was drinking and driving and had my horn start honking intermittently while following a cop on University Avenue.
I don't do stuff like that anymore.
