Corsa Tach
csistak
Corsa Tach
Post by csistak »
Hi, Looking for someplace that can fix a Corsa Tachometer?
Re: Corsa Tach
State your problem. The electrical components are repairable EXCEPT the meter movement.
If the needle won't return to zero and bounces at the slightest vibration the meter return spring(s) are probably broken. They are not practical to repair.
If the tachometer works, but doesn't read correctly that is usually repairable.
I've done about six for myself and club members, but to properly calibrate them can take many hours, or a few minutes. I think that's why folks that did them have quit (or at least no longer advertise) . I never charged to do them for buddies so I didn't have to worry about quesstimating fees.
If all else fails you might find a good used working unit.
DON'T throw away a bad tachometer as a kit to upgrade them with modern components will eventually be available.
csistak
Re: Corsa Tach
Post by csistak »
Thanks for the info.
scottymac
Re: Corsa Tach
Post by scottymac »
These folks gave me a quote of $295 to put in new guts compatible with electronic ignition. They're not fast, but I was happy with the work they did on my cylinder head gages.
https://www.clocksandgauges.com/home.html
