Hello all! I’m resealing my differential and want to make sure I don’t miss one. Specifically, I’d like to know if there is a seal between the throw-out bearing shaft and the differential carrier itself. It looks like there’s some sealant around the shaft. Based on the rest of the car, I doubt that’s factory. Anyways, is this a common area for leaks?
Chris
1966 Monza 140-HP
Ramstein, Germany
Differential Seals
Differential Seals
Chris
Geiselberg, Germany
'66 Monza 3-Speed/140
Geiselberg, Germany
Re: Differential Seals
Not common for leaks. The throw out bearing shaft is a press fit from inside the differential. A little sealant perhaps but no seal or gasket in this location except the input shaft seal inside the throw-out shaft. Make sure your input shaft is straight.
That sealer could be factory. It looks similar to what I've seen.
Don't forget the split support ring on top of the seal.
