Stuck Turn Signal Bulb, '66 Corsa
I am trying to remover the front turn signal bulb on my '66 Corsa, but it is stuck in its socket. Is there a safe way to loosen it; I am afraid to apply too much force which might break the bulb. What is the best way to loosen it, spray WD40 ?
Re: Stuck Turn Signal Bulb, '66 Corsa
I had the same thing recently on both sides up front. I removed the whole light socket assembly (2 nuts & brackets on back) to better access the bulb. Plenty of WD-40, patience, and rocking the bulbs back and forth. Don't rush it, both of mine actually came out intact. Access was aided by the lower fender wells being rusted thru!
Removing the whole socket/reflector assembly also made it easier to clean out the socket with scotchbrite. That internal oxidation is what cause the binding anyway.
I have sometimes just broken the bulb and used a needle nose plier to grab the edge of the base and force bend and twist them out.
Thank you erco and terribleted for your helpful suggestions, I appreciate this. I finally took out the whole directional light assembly and worked the bulb loose with WD40; this also gave me a chance to do some rust treatment in the well where the directional light assembly is located
That is something you want to be very careful with. I've heard stories of severe cuts in people's fingers from broken bulbs.
Yup that is why I have broken a few with a tool before impaling my finger. I also use a thick glove if they do not play nice.joelsplace wrote: ↑Fri Sep 25, 2020 10:34 am That is something you want to be very careful with. I've heard stories of severe cuts in people's fingers from broken bulbs.
