Well i noticed a small circular hole near the area where the shift linkage goes.
It is on my 61 Lakewood 3 Spd
After doing some quick digging around I found out it requires a plug that Clark's sells (C503)
I forgot to take a picture but here is a sketch below to see the hole I speak of.
My question about this "hole" is I did heavy cleaning with engine degreasers, scrapers for the dirt & the garden hose. Getting all the above in that hole or maybe none at all, is there anyway to clean that out with a small vacuum cleaner attachment or can I take the shield off the clutch fork area to see more in there to clean or inspect? Just curious as I noticed this hole while cleaning the drums up.
Thanks for the help!
Kyle
Kyle Storm
1964 Corvair Monza/110hp/4 Speed
1961 Corvair Lakewood/80hp/3 Speed
Hole in Bell-housing?
-Kyle Storm
1964 Corvair Monza Coupe 110/4spd
1964 Corvair Monza 4 Door 110/Automatic A/C
1961 Corvair Lakewood 500 85/3spd (restoring)
1961 Corvair Greenbrier 110/4spd (sold)
Re: Hole in Bell-housing?
You can take a peak under the dust cover for debris but I doubt you have anything to worry about.
I will have to try!
Here is an attached picture of the area. I think I have removed about 50lbs of stuck on dirt from this wagon so far. Clearly have more to go!
Thanks again!
Kyle Kyle Storm
Thanks again!
Kyle Kyle Storm
-Kyle Storm
That plug is missing on most Corvairs in my experience. It is good to have have the plug.
Gotcha, I will tack it on the next batch of parts from Clark's I get.
Thanks for information guys!
Kyle
Kyle Storm
Kyle
Kyle Storm
-Kyle Storm
