Oil cooler
monzadon
Oil cooler
Post by monzadon »
How much torque do you use for the oil cooler? My book says 50 foot pounds, to me that sounds pretty high, i am afraid I'll pull the threads out of the head with that amount of torque, if that should happen i could put in a heliCoil but i really don't want to have to do that
Re: Oil cooler
I do the torque by feel and only get out the TQ wrench on serious stuff and this isn't one of those bolts. Someone will post a number for you soon because we all have to get a feel for it but keep in mind that the oil cooler has two rubber ring compression gaskets with a positive stop on the mating parts so you cannot over compress those seals past the point intended. Once the oil cooler bolt has been tightened to the point that the gaskets are compressed and the aluminum face of the cooler is touching the aluminum adapter block, any additional tightening of the bolt is not doing anything further to compress the seals. I would not tighten that bolt any more than I would the bolt on top of the oil filter. You did put in two new seals correct? ::-):
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
Re: Oil cooler
monzadon wrote:...My book says 50 foot pounds, to me that sounds pretty high...
:whoa: :eek:
If you want engine torque specifications, most can be found in the Corvair Shop Manuals (attached). The oil cooler seals are a foam-like rubber material that crushes between the oil cooler and the oil cooler adapter, so the amount of torque applied is not critical to the seal effectiveness, as long as the bolt is not over-tightened enough to strip the aluminum threads or so loose that vibration causes the bolt to loosen. The accuracy of a foot pound torque wrench at such a low number (8-12 ft. lbs.) is marginal. Better to use an inch pound torque wrench for accuracy (96-144 in.lbs) (To convert foot-pounds to inch-pounds, multiply the foot-pound value by 12).
VITON oil cooler seals probably hold up better as they withstand prolonged heat exposure better and are less-likely to become hardened or deformed so they are less-likely to develop leaks.
:link: http://www.corvair.com/user-cgi/catalog.cgi?show_page=4
Part number C123C: VITON OIL COOLER SEALS-SET 2
Weight: 0 lbs 2 oz
Catalog Page(s): 4,12(60)
Price:
1 - 1 $ 4.25
Oil Cooler Torque Specs (1961)
Oil Cooler Torque Specs (1965)
:chevy:
1965 Corvair Chassis Shop Manual - SECTION - SPECIFICATIONS.pdf
(2.83 MiB) Downloaded 10 times
1961 Chevrolet Corvair Shop Manual - Section 12 - Specifications.pdf
(346.54 KiB) Downloaded 10 times
monzadon
Re: Oil cooler
Post by monzadon »
Thanks for all.the information i read the torque specs wrong i have a inch pound wrench and regarding the seals i did replace them from clarks but when i took the cooler off somehow one was missing and the bolt that holds the cooler on ended up.breaking about one inch from the end the center of the bolt looked like it corroded causing it to break
