Leaf spring
Connrod
Leaf spring
Post by Connrod »
I bought a 1964 rear section for my trike. It has a leaf spring going side to side. What holds it in place on the trans?
Re: Leaf spring
1964 Corvair Transverse Leaf Spring (Suspension component attaches to the differential in the center)
The 1964 Corvair differential housing is the only one that has the required mounting points.
1964 Corvair Transverse Leaf Spring Components
If you need a good used parts source... you might contact the Corvair Ranch in Gettysburg Pennsylvania. They know a lot about parts substitutions, have a large inventory of used Corvair parts and may be able to help you. Recommend you give them a call to discuss your needs...
​Phone: 717-624-2805
Email: findit@theranch.today
:chevy:
1964 Supplement - Chevrolet Corvair Shop Manual - Section 3 - Suspension.pdf
(564.64 KiB) Downloaded 15 times
1961 Chevrolet Corvair Shop Manual - Section 3 - Suspension.pdf
(1.67 MiB) Downloaded 14 times
Chevrolet 1960-1969 Corvair Parts Catalog - GROUP 7 - FRAME - SPRINGS, BUMPERS.pdf
(1.92 MiB) Downloaded 15 times
Connrod
Re: Leaf spring
Post by Connrod »
Thanks, I will have to check mine, not sure what year my driveline is. I did get it out of a first gen though
Re: Leaf spring
Connrod wrote:
Tue Aug 04, 2020 6:58 pm
The leaf spring and differential that has the mounting bosses was 64 only
Connrod
Re: Leaf spring
Post by Connrod »
Can the differential be welded to?
Re: Leaf spring
Not in the car. Cast iron isn't much fun to weld. Why?
Re: Leaf spring
You could simply choose to omit the leaf spring, if your differential housing is not a 1964 with the necessary mounting pad. It is hard to know just what suspension configuration will work best on a custom trike installation. The 1964 coil springs were redesigned to match the extra spring rate offered by the transverse leaf spring. Earlier 1961-1963 coil springs could be tried, but the existing coil spring rate alone may be OK with your trike.
:dontknow:
Re: Leaf spring
Brad is correct on the spring rate and I wouldn't think you would want the transverse leaf on a trike. It reduces roll stiffness in the rear to make the front roll stiffness a higher percentage. Since the trike has no front roll stiffness the design would be bad from what I understand.
