65 Wiring Harness Location
doug6423
Post by doug6423 »
I bought a new harness and not sure if it goes down the center of the tunnel or off to the side the way i have it in the picture.
Would appreciate feedback before I close it up.
Thanks,
Doug
:dontknow:
65 Monza
Cincinnati, OH
erco
Re: 65 Wiring Harness Location
Post by erco »
I can't answer your question but I had to comment that your car has the cleanest underside I've ever seen. WOW, better than a new car! Jealous!
doug6423
Post by doug6423 »
erco wrote:
Sat Aug 01, 2020 8:56 pm
Thank you!
It started out as just replacing the clutch cable that broke in May, but....
I washed the underside, and then did the 3 step POR-15 treatment to it. It's brushed on so it is NOT a show car.
I've done Roger Parent clutch cable, aluminum pulleys, and divots for the fuel linkage. Clark's stainless steel brake & fuel lines, and rubber boots. Redoing the shifter and adding a short shifter.
I'll post the finished pictures when I get there... hope it's soon.
65 Monza
Cincinnati, OH
