Front pump and TV pressures
albjerryg
Post by albjerryg »
I wanted to check the front pump and throttle valve pressures on my 1966 Corvair with automatic transmission. I am not sure where the ports are located to check the psi. Is it in the rear toward the front of the car or where. I have enclosed a picture of the rear, Thanks for any help. Jerry
Corvair 23.JPG (32.35 KiB) Viewed 104 times
Corvair 24.JPG (36.75 KiB) Viewed 104 times
Re: Front pump and TV pressures
That is the front pump. All the bolts with the slots hold things together. The outer ones hold the pump to the case and the inner ones hold the pump halves together. There should be some pipe plugs to check pressure.
What is yours doing?
albjerryg
Post by albjerryg »
Afraid I did not understand your reply. I am looking for the location of the ports to check the pressures. Thanks Jerry
I have attached a Corvair Powerglide maintenance manual: Corvair Powerglide Automatic Transmission Service Guide. I had to divide it into 5 parts to make the files sizes small enough to upload to the Corvair Forum website. I believe the information you asked for can be found in Corvair Powerglide Automatic Transmission Service Guide - PART 5 OF 5, page 43-L (Adobe Reader page 7 of 10 in that section). I have shown that page below...
Left click the image below once to enlarge for better viewing,
Left-click a second time for maximum enlargement...
Corvair Powerglide Service Guide - Hydraulic Pressure Data
The information is also available on page 7-54 — 7-55 of the attached 1965 Corvair Chassis Shop Manual - SECTION 7 - AUTOMATIC TRANSMISSION
:chevy:
Corvair Powerglide Automatic Transmission Service Guide - PART 1 OF 5.pdf
(8.83 MiB) Downloaded 5 times
Corvair Powerglide Automatic Transmission Service Guide - PART 2 OF 5.pdf
(9.53 MiB) Downloaded 4 times
Corvair Powerglide Automatic Transmission Service Guide - PART 3 OF 5.pdf
(8.87 MiB) Downloaded 4 times
Corvair Powerglide Automatic Transmission Service Guide - PART 4 OF 5.pdf
(9.78 MiB) Downloaded 4 times
Corvair Powerglide Automatic Transmission Service Guide - PART 5 OF 5.pdf
(8.16 MiB) Downloaded 4 times
1965 Corvair Chassis Shop Manual - SECTION 7 - AUTOMATIC TRANSMISSION.pdf
(8.61 MiB) Downloaded 3 times
albjerryg
Post by albjerryg »
I thanks you for the information I have look at it but still don't know where the 2 ports are for checking the pressure. I assume you do not have to take anything apart to assess the ports???? Thanks Jerry
albjerryg
Post by albjerryg »
Tanks for the pictures I got the front pump it looks like it is a 5/16" by 18 threaded connection. Thanks a bunch Jerry
I'm pretty sure it is 1/8 NPT.
