Idler Arm
Idler Arm
An alignment shop recommended I replace my idler arm on my 65 corsa and decided to mill the top off of the end that attaches to the linkage. I expected to find a roller bearing where the tapered pin rides. I found a rubber washer a thin steel plate and a slotted steel bushing that the tapered pin rids in. I put the tapered pin back in but could not feel any play in the pin. I was just curious as the idler arms are not rebuildable. Just an observation. Larry
Re: Idler Arm
http://www.corvair.com/user-cgi/catalog ... w_page=151IDLER ARMS
Bad idler arms can cause squeaks and shimmy. The Clark Repros all have grease fittings.
Part number C177A: 65-69 IDLER ARM-*ORIGINAL STYLE -REPRO
Weight: 3 lbs 0 oz
Catalog Page(s): 151,156(1)
Price:
1 - 1 $ 79.65
2+ $ 75.70
Recommend you take a look at the Pitman Arm Bushing on the other side, and replace it if worn.
https://ssl.corvair.com/user-cgi/catalo ... N&page=156
- 1965 Corvair Chassis Shop Manual - SECTION 3 - FRONT SUSPENSION.pdf
- (4.67 MiB) Downloaded 15 times
- 1965 Corvair Chassis Shop Manual - SECTION 9 - STEERING.pdf
- (4.31 MiB) Downloaded 14 times
- 1965 Corvair Assembly Manual - FRONT SUSPENSION.pdf
- (1.76 MiB) Downloaded 14 times
- 1965 Corvair Assembly Manual - STEERING.pdf
- (1.92 MiB) Downloaded 12 times
Re: Idler Arm
If the idler arm is bad and the pitman arm bushing has not been recently serviced it may well be bad also. Either one being loose will accelerate wear on the other. Check it and replace it at the same time if needed.
Re: Idler Arm
Clark was out of the idler arms. my pitman arm bushing is in good shape. I found that an idler arm off a 66 corvette has a heavier casting. The distance between the pins is the same and the taper on the pin in the linkage is the same. I made minor modifications to the arm that bolts to the body and fit it to my car. Larry
