Instrument panel removal
albjerryg
Post by albjerryg »
I have a 1966 Corvair with Auto. Transmission, do I need to remove the transmission bezel to remove the instrument panel? Thanks Jerry
Tx. Bezel.jpg (12 KiB) Viewed 283 times
Re: Instrument panel removal
Although I have never owned a late model Corvair with an automatic, I hope the attached manuals are of some help...
:chevy:
1965 Corvair Chassis Shop Manual - SECTION 7 - AUTOMATIC TRANSMISSION.pdf
(8.61 MiB) Downloaded 4 times
1965 Corvair Assembly Manual - INSTRUMENT PANEL.pdf
(2.38 MiB) Downloaded 5 times
1965 Corvair Assembly Manual - AUTOMATIC TRANSMISSION.pdf
(2.26 MiB) Downloaded 4 times
corvairsince70
Post by corvairsince70 »
No, you do not have to removed the bezel. On the drawing of the selector in the circle above, you only have to remove nut (#4) and e-clip (#1). The nut is ⅝" and is a little tough to get to but I just did it yesterday. The clip is easier to remove if you put it in Low so it is easier to see. It is very small and easy to lose.
To install just put the cable through the hole while you put the nut over the end. Tighten the nut and then put the cable end over the stud and replace the e-clip.
albjerryg
Post by albjerryg »
OK good thanks>>>Jerry
