Boyne Turn Signal Switch 67-69
erco
Post by erco »
Corvair Kid posted an excellent article detailing two different turn signal switches in 67-69 cars at http://www.corvairkid.com/67-9signal.htm . My '67 has the "Boyne" switch (vs the Delco switch). Clark's price is $85. After some surfing I found a $13 sub-assembly on a Firebird site which may be all I or someone else needs to repair a Boyne switch. https://www.firebirdcentral.com/Product ... DAS%2D764C There may be other interchangeable parts on that site, this turn signal lever looks just like my Corvair's: https://www.firebirdcentral.com/Product ... e=STE%2D22 Costs more than Clark's though...
Sister car sites at https://www.camarocentral.com/1967_1968 ... as-764.htm and https://www.musclecarcentral.com/1968-1 ... -24-ch.htm may be worth poking around too.
Re: Boyne Turn Signal Switch 67-69
Thanks for the info!
erco
Post by erco »
Turns out Clarks actually sells that part too. :redface:
But I found it for under $15 shipped at https://www.ebay.com/itm/323377255245
What is the Clark's number?
erco
Post by erco »
http://www.corvair.com/user-cgi/search.cgi?part=C4665
It's been a while since I ordered from Clark's. Mostly good prices but their shipping costs are ridiculous. Are they unaware of flat-rate shipping boxes?
Their estimated shipping is usually high but they charge actual shipping. They will use flat rate boxes if they cost less. My shipping from them seems to always be less than estimated and they are very good at packing things in tiny boxes.
erco
Post by erco »
Sounds good, thanks. By their estimate I was gonna go broke shipping a pitman arm bushing and sway bar bushings!
Put a note in the order asking them to ship the cheapest way possible.
erco
Post by erco »
DOH! Just saw that Autozone has 'em for $10. https://www.autozone.com/electrical-and ... 0_0_218724
erco
Post by erco »
My Ebay repair part arrived yesterday so I installed it this morning. Pretty straightforward, just had to clip and solder two wires. I didn't remove the wiring harness, there was plenty of cable to slide up the steering column cover to gain room to work. Obviously care is required to work with brittle old wires. The only bad thing about the part was that both wires are red, even though polarity is critical! Same on all the replacement parts I have seen. I took plenty of reference photos during R&R, I'm attaching some here for reference. Nice to finally have latching turn signals for the first time since I bought the car in 1980. :)
I posted a video of the installed part showing latch & cancel functions at https://youtu.be/8ceKaZshPZg
Edit: Anyone wishing to do this (especially working in the car, as I did) should be careful not to lose two flat metal springs (red arrows, last pic) which are loose and can fall out. Looks like a single spring but it is in fact two back to back.
I embedded your YouTube video in your last post. I placed it into your post so that you can click on the edit button to see how a YouTube video is embedded. You do not use the internet address at the top of the YouTube video. To get a correctly formatted address, click on the SHARE button below the YouTube video, and copy the special URL address in the SHARE dialog box. Then paste that address between the share_youtube markers on the Corvair Forum.
Thanks for documenting your work so clearly with a video and with photos. :tu:
Autozone is cheaper than Rockauto. I've never seen that on the same part.
The Dorman part has a lifetime warranty too!
Does anyone know where to find a real Dorman catalog? You can only look up by application on their site which doesn't work for parts like this.
I need a horn contact ring for my '66 Malibu. Hopefully I have enough Corvairs to be allowed a couple of other cars without getting into too much trouble here.
erco
Post by erco »
joelsplace wrote:
Sat Jun 20, 2020 11:55 am
That means less and less to me each year. :pray:
I agree, Dorman's website is kinda useless. You know they have what you want, but you can't find it.
It doesn't help that various places use inconsistent terminology. Clarks doesn't use "turn signal", can't search it. Only "directional signal".
Autozone calls this part a cam. Clarks calls it a canceling plate. Clarks calls the canceling cam the more cylindrical part with the brass horn ring and post which rotates with the steering wheel to hit and release their cancelling plate.
I'll DIY one before I pay $32 for one. What are they thinking? http://www.corvair.com/user-cgi/search.cgi?part=C2660
Apparently only Corvair and Corvette use this particular part, so they charge Corvette prices. :angry:
I think that is the one I need for my Malibu. I was hoping to not pay $30+ either. Dorman probably makes it but I can't figure out how to find it. I bought the latching part from Clark's for my Malibu. It had the GM part number on it and I searched for it on their site. It was the same as one of the telescopic Corvair columns.
I'm with you on the warranty. I would rather buy a part that will last but I haven't figured out how to do that. I bought a front wheel bearing from Napa for my Buick because I hoped it was a better part. It lasted about 2 years and only had a 1 year warranty. I bought a window regulator for the same car from Napa and it lasted about a year but it had a lifetime warranty so at least I didn't have to buy another one.
I have been buying batteries from them and now some are over 6 years old and no failures yet.
joelsplace wrote: » Sat Jun 20, 2020 1:55 pm
...Does anyone know where to find a real Dorman catalog? You can only look up by application on their site which doesn't work for parts like this.
:google: :search: Dorman Catalog
I Googled "Dorman Catalog", and...
:link: https://www.dormanproducts.com/pages/re ... gin=topnav
Just choose a catalog, click on the Adobe Reader icon in the catalog image, and download the desired catalog in Adobe Reader (.pdf) format.
Thanks but I couldn't find any turn signal parts in any of those catalogs. Maybe I'm not smart enough.
