'67 Wiring Diagrams Online?
erco
Post by erco »
I'm looking for a good color wiring diagram for my '67 Monza 140 coupe. Time to sort out some issues. Pretty sure it should have hazard flashers, but there was nothing but a mysterious hole in the steering column ever since I bought the car many moons ago.
I know the horns are inside the headlight shells, but where is the horn relay?
I'm about to order a wiring diagram from Ebay but figured I'd ask here first to see if they were online.
acarlson
Re: '67 Wiring Diagrams Online?
Post by acarlson »
Here is a post from Brad Bodie which has the known wiring diagrams:
viewtopic.php?f=225&t=12968
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
erco
Post by erco »
Perfect! Very helpful, thanks Alec & Brad!
The 1967 wire color codes are somewhat different, but the circuits are basically the same. You should be able to sort it out. The diagrams were copied modified and assembled from the 1965 Corvair Chassis Shop Manual. The horn relay is on the passenger side of the trunk.
I recently was given some diagrams from the 1969 Supplement, which you may find useful for comparison with the 1965 schematics. I haven't had a chance to go over them or combine them yet.
ORIGINAL SHOP MANUALS
:link: http://www.corvair.com/user-cgi/catalog ... w_page=244
I attached some sections of the 1965 Corvair Chassis Shop Manual and the 1965 Corvair Assembly Manual that you may find useful.
:chevy:
1969 Corvair Trunk Wiring Diagram (From 1969 Supplement)
1969 Corvair Fuse and Instrument Panel Wiring Diagram (from 1969 Supplement)
1969 Corvair Instrument Cluster Wiring Diagram (from 1969 Supplement)
1969 Corvair Engine Compartment Wiring Diagram (from 1969 Supplement)
1965 Corvair Assembly Manual - ENGINE COMPARTMENT WIRING.pdf
(1.58 MiB) Downloaded 5 times
1965 Corvair Assembly Manual - FRONT LIGHTING.pdf
(1.16 MiB) Downloaded 5 times
1965 Corvair Assembly Manual - INSTRUMENT PANEL.pdf
(2.38 MiB) Downloaded 5 times
1965 Corvair Chassis Shop Manual - SECTION 6Y - ENGINE ELECTRICAL.pdf
(8.51 MiB) Downloaded 5 times
1965 Corvair Chassis Shop Manual - SECTION 12 - BODY & CHASSIS ELECTRICAL.pdf
(6.99 MiB) Downloaded 5 times
