1967 Monza 4 dr chrome roof trim removal
I am preparing my Monza for paint, and have a question about the strip of trim between the roof and rear quarter panel. As in how to remove it?? Thanks in advance!!
Re: 1967 Monza 4 dr chrome roof trim removal
What strip? Most cars have no strip separating the roof and the 1/4 panel.
Yeh, I'm afraid of that being add on. I will take a picture of it. Has 2 tone paint, separates the roof line from body...
Corvairvan wrote: ↑Wed May 13, 2020 8:01 pm I am preparing my Monza for paint, and have a question about the strip of trim between the roof and rear quarter panel. As in how to remove it?? Thanks in advance!!
There were a few with 2 tone that had this. Very few. I am honestly not sure how the divider piece removes having never worked on one. They may have external clips. If there are no crews from the inside then there must be clips. Hopefully someone who has played with one of these rare parts will chime in.Corvairvan wrote: ↑Thu May 14, 2020 1:56 pm Yeh, I'm afraid of that being add on. I will take a picture of it. Has 2 tone paint, separates the roof line from body...
While uncommon the two tone paint with trim is not that rare on 4 doors. It's been said a number of "500" models were done in two tone by Chevrolet to increase sales. Contact AZDAVE on the Corvair Center Forum. http://corvaircenter.com/phorum/list.php?1Corvairvan wrote: ↑Wed May 13, 2020 8:01 pm I am preparing my Monza for paint, and have a question about the strip of trim between the roof and rear quarter panel. As in how to remove it?? Thanks in advance!!
I recall Dave has at least one two tone four door and he is knowledgeable about Corvairs. He might be able to help describe how to get the trim off for painting. Dave also makes the neat front clear turn signal lens that were only used on Euro-spec. Corvairs. Sure look nicer than those orange lens with some paint colors.
I have a lot of Sport Sedans and none have that trim. I've never seen it before the above picture.
Thank You Sir!!
The attached section of the 1966 Fisher Body Service Manual illustrates the Late Model Corvair Reveal Moldings, including the unique and rare optional Rear Quarter Belt Reveal Molding (Item 7) that is the topic of discussion here. This two-tone factory paint option and its associated reveal molding makes your sedan very rare. I would recommend considering retaining this unique factory finish that makes your rare 1967 4-door sedan (last year — only 3,157 produced) even more-exclusive!
TWO-TONE (Lower/Upper — Available on 10539 [4-Door Sport Sedan - 5 Passenger] only)
RPO: CD — White/Medium Blue
D = Nantucket Blue Lucite No: 4815L Rinshed-Mason No: A1899 Ditzler No: DDL13349
C = Ermine White Lucite No: 4024L Rinshed-Mason No: A1199 Ditzler No: DDL 8259
Body Tag Data...
Late models (65-68) have a different paint code. They used a two character code employing two letters for hardtops and a one letter /one digit code for convertibles. Ex. R-R = Regal red, R-C = two tone white top/red bottom, R-1 = Convertible with red paint and white Conv top.
1967 Fisher body tags ACC line. (WRN)
The Letters are listed in groups. Letters following a number is in that group. The code letters are listed in the order they would appear. Some letters are in more than one group
Most 1966 codes carried over to 1967 unchanged
First Group ( no numeric indicator)
D = RPO C06 Power Top (Manual top standard, no indicator)
O = Two tone paint trim piece (sedans only)
L = folding rear seat (500 series only)
2 = Second Group
M = RPO M35 Powerglide Automatic
D = RPO C60 Air Conditioning
R = RPO U80 Rear speaker
S = RPO U73 Rear ant.
U = RPO U57 Stereo tape system
H = Heater delete
3 = Third Group
(no group three options found)
4 = Fourth Group
F = Remote outside mirror RPO D33
5 = Fifth Group
Y = RPO A49 Deluxe Seatbelts ( Stainless Steel Push-button Buckles)
O = Seatbelt delete? ( No cars found with this code, but may carry over from 65)
The opening pages of the attached section describe and illustrate the mounting characteristics of each piece of molding to help you to safely and carefully remove it for body painting.
viewtopic.php?f=225&t=6007
- 1966 Fisher Body Service Manual - SECTION 12 - EXTERIOR MOLDINGS (CORVAIR).pdf
- (1.26 MiB) Downloaded 15 times
- 1967 Chevrolet Corvair GM Heritage Center Specs.pdf
- (1.52 MiB) Downloaded 12 times
That would indicate there may be some nuts on studs accessible from the inside (likely at the ends or one end maybe) as well as some T-studs with little plastic clips that the trims snaps on to.
I have a 66 four door. It is NOT a two tone. I did remove the interior years ago for a re-do. Inside on the "C" pillar (rear roof pillar) there is a hardboard panel behind the headliner. Best left alone unless you want to install a new headliner. Below the headliner is a painted hardboard panel that can be carefully removed. Behind the panel are a couple holes in the body frame that might allow access to the trim hardware.
Good luck.
Good luck.
You guys are awesome! I was wondering about being bolted from the inside....time to do some careful excavation....
