1962 spyder timing problems
Trevor monninger
Post by Trevor monninger »
I have a 1962 spyder convertible and I have dwell @32 new plugs, wires ,cap ,points and it pings when hard shifts and in 4th gear and timeing is only @16 degrees with factory boost retarder in working order.
Re: 1962 spyder timing problems
What fuel are you using? Are the oil cooler and heads clean?
miniman82
Post by miniman82 »
16 degrees where, at idle? Check the manual, static timing is much higher.
Click it!
Trevor monninger
miniman82 wrote:16 degrees where, at idle? Check the manual, static timing is much higher.
Running 93 octane and yes idle timing set and should be 24 but pings when that high
Too lean? Air leak?
