66 Corvair conv
monzadon
66 Corvair conv
Post by monzadon »
I am reparing my 140 motor because of dropped valve seats and I am going to replace the rings and rod bearings while I have it out of the car, my question is how hard is it to replace the crank seals without splitting the case?
Re: 66 Corvair conv
Splitting the case is not needed to change the crankshaft end seals
Re: 66 Corvair conv
Rear one comes right out but the front presses into the bell housing from the inside. Neither seal touches the crank case.
monzadon
Re: 66 Corvair conv
Post by monzadon »
Thanks for the information, where can I find the information on what has to be done to change these seals?
Re: 66 Corvair conv
I've attached a portion of the 1965 Corvair Chassis Shop Manual as a reference, and included a couple of videos to help you with the seals.
1965 Corvair Chassis Shop Manual - SECTION 6 - ENGINE (Copy Attached)
Engine Rear Housing Seal Replacement.... Page 6-51
Flywheel Housing Seal Replacement........Page 6-51
Dave Motohead Corvair YouTube Videos... :link: https://www.youtube.com/user/davemotohead1/videos
Clark’s CRANK SEALS – the BEST QUALITY
:link: http://www.corvair.com/user-cgi/catalog ... ow_page=7A
NOTE: I have read comments from several sources on the Corvair Forum that DO NOT recommend installation of Viton crankshaft seals. They apparently do not seal as well as conventional seals when used in the rear housing and clutch housing. Viton o-rings and gaskets are definately recommended for other locations throughout the engine, however.
:chevy: :wrench:
1965 Corvair Chassis Shop Manual - SECTION 6 - ENGINE.pdf
(19.37 MiB) Downloaded 11 times
