Back up light switch Location
bazookajoe
Post by bazookajoe »
Working on my '63 three speed manual monza ,getting all the lights to work and am unsure as to the location of the back up light switch. I read that it is in the tunnel , but where in the tunnel?? Is it in the rear near the engine, or in the front under the driver? Thanx in advance.
Re: Back up light switch Location
it is in the tunnel. it is not at the rear but more toward the front. Take off the long tunnel pan under the car to access it.
:nono: Be sure to place the car safely on jack stands to permit you access to the tunnel that runs down the center of the vehicle.
See 1961 Chevrolet Corvair Shop Manual - Section 8 - Electrical Systems, page 8-44 for the schematic wiring diagram, and page 8-55 for the BACK-UP LAMP SWITCH REPLACEMENT (3-SPEED ONLY)
1962-1963 Supplement - Chevrolet Corvair Shop Manual - Section 8 - Electrical Systems has a much -better schematic diagram that includes the backup switch.
:link: http://www.corvair.com/user-cgi/catalog ... N&page=84B
Part number C5364: 61-65 4SP BACK-UP SWITCH *EXACT REPRO BOOT & GASKET (C383A) INCLUDED
Weight: 0 lbs 10 oz
Catalog Pages(s): 84B
Price: $ 53.65
Part number C8379: 4 SPEED BACK UP SWITCH FIX-THEY LEAVE OLD SWITCH IN PLACE-THIS WORKS OFF SHIFT ROD
Weight: 1 lbs 0 oz
Price: $ 39.35
1156 bulbs only belong in the backup light sockets. The two locking pins in the 1157 bulb are positioned at different heights on the side of the bayonet base/lamp socket, to ensure that they are properly inserted.
:chevy:
1961 Chevrolet Corvair Shop Manual - Section 6d - Manual 3-Speed Transmission.pdf
(688.29 KiB) Downloaded 6 times
1962-1963 Supplement - Chevrolet Corvair Shop Manual - Section 6d - Manual 3 & 4-Speed Transmission.pdf
(108.75 KiB) Downloaded 6 times
1961 Chevrolet Corvair Shop Manual - Section 8 - Electrical Systems.pdf
(3.28 MiB) Downloaded 6 times
1962-1963 Supplement - Chevrolet Corvair Shop Manual - Section 8 - Electrical Systems.pdf
(2 MiB) Downloaded 6 times
bazookajoe
Found it immediately with your help....found it ,fixed it, thanx guys
