Rear Brake Cylinders
Corvaircar
Post by Corvaircar »
I am about to change the rear brake cylinders on my 66 Monza and see that there is not much room to get a wrench on the bolts. Can I unbolt the hub and pull it off to do this or is there an easier way. If I do this do I have to remove the drive shafts?
Thanks for any advice.
Robbie
Re: Rear Brake Cylinders
You can not remove the hub readily. Take off the bolts with a box wrench...6 point is best if you have one. You can loosen the hub assembly at the 4 large bolts and maybe gain a little space by forcing a wedge of some sort between the backing plate and the torque arm. If they will not come off chisel the heads off and replace with new along with the new wheel cylinders. Applying some PB blaster or other break free type solvent the day before can help. I usually do not have any trouble getting these off with a 3/8 6 point box wrench. If someone has swapped them to 7/16 heads clearance is a little harder but still generally not much trouble.
:link: http://www.corvair.com/user-cgi/catalog ... w_page=143
Brake Parts
Part number C894: BRAKE CYLINDER-65-69 LEFT REAR BOLTS- C2110
Weight: 1 lbs 0 oz
Catalog Page(s): 143
Price: $ 22.20
Part number C895: BRAKE CYLINDER-65-69 RIGHT REAR BOLTS- C2110
Weight: 1 lbs 0 oz
Price: $ 22.20
BOLTS: Not Included with wheel cylinder. Replace those rusted broken bolts. "1" = 1 Set for 1 wheel cylinder (2 bolts, 2 LW)
Part number C2110: GRADE 8 60-64 R & 65-69 F/R WHL CYL BOLTS- "1" DOES "1" CYLINDER (2 BOLTS)
Weight: 0 lbs 2 oz
Catalog Page(s): 143,177
Price: $ 2.40
Brad I personally hate those 7/16 head bolts they supply. The 3/8 heads installed at the factory are easier to get a wrench on.
terribleted wrote: » Thu Mar 26, 2020 9:44 pm
Do you happen to have the bolt specs for these bolts — thread specs and length. Must they be Grade 8? The large round casting shape of the wheel cylinder would appear to take most of the torque load as it anchors in the backing plate. The small bolts only appear to anchor the cylinder in position. There are no bolt dimensions or torque specs in the Shop Manual. Clark's offers there large head bolts in Grade 8, but with unspecified torque specs in the shop manual the bolt tension is unlikely to be critical.
:chevy:
1965 Corvair Assembly Manual - BRAKES.pdf
(2.29 MiB) Downloaded 7 times
1965 Corvair Chassis Shop Manual - SECTION 5 - BRAKES.pdf
(4.6 MiB) Downloaded 7 times
Not sure of grade of the factory bolts, but they do not appear to be hardened. The bolts are 1/4x20 of course. I am sure Clark's supplies the 7/16 heads as they are the most common ( and likely cheapest) 1/4x20 head size bolts that are available in the necessary short length. A good hardware store can hook one up with 3/8 head 1/4x20 bolts that are short enough. I am sure I have used the 3/8 head 1/4x20 bolts the Clark's sell for engine shrouds in for these as well, but I can not remember if I needed to shorten them a little? I am thinking they do need to be a touch shorter, this is why Clark's supplies washers with their 7/16 head bolts....it is not to hold them in place but it is because they are too long, the washers make access worse as well as it puts the bolt heads even closer to the torque arm.I have not had an issue getting what is in place off any cars in a very long time and I either reinstall or cleanup and reinstall depending on the level of the repair.
Corvaircar
Still having a terrible time getting to the cylinder bolts, I think they are rounded off. How far should I be able to pry the hub away from the yoke? Difficult to get a chisel on these bolts.
To remove the hub I believe that I have to pull the yoke from the inside. I watched Motohead Dave do this and he had a yoke puller, I am going to suppose that he made that himself.
My bearings feel excellent and I would like to use them again. Would this be okay?
Good thing I am shut down from working right now and have all kinds of time.
You can not really remove the hub on your 65 as this would require removing the hub assembly and using a press (only really done when replacing the hub bearings). You can remove the axles and then remove the entire hub assembly after removing the 4 9/16 nuts that hold it to the car. I suggested above loosening the 4 nuts and trying to force the backing plate out some. This will not be easy as the axles will want to hold the hub assembly and backing plate in against the suspension arm, but forcing a large screwdriver or similar in between the center of the backing plate and the suspension arm with the hub assembly mounting bolts loose should result in a little more space. An air chisel makes chiseling these off easier as hammer swing space is annoying. If you decide to remove the hub assembly to get to them, once the axles are removed and you have taken off the 4 hub assembly bolts you should have plenty of space without taking the assembly fully off the car. In order to remove the assembly from the car it will be necessary to remove the e-brake cable from the backing plate and then you rotate the axle yoke so it is up and down. The assembly comes out of the arm by rotating it downward so the upper yoke end clears the arm. It will not come straight out. CAUTION the axle wants to hold the wheel hub assembly in toward the transaxle, so, when you loosen the u-joint bolts the arm will travel outward. To remove the axles use a cargo ratchet strap around the suspension arm and the transaxle to pull the arm in tight, then remove the bolts at the axle outer end u-joint and carefully release the strap. it is all too easy for a u-joint bearing cup and it needle bearing to fall on the floor resulting in needle bearing loss and the need for replacing the u-joint at that point. To reinstall the axle you put the u-joint ends into place while tightening the cargo strap until the u-joint is seated inn the hub yoke and then install the u bracket and bolts (here again to avoid bearing cups falling).
Corvaircar
My thanks, your comments helped me out and I appreciate the time you took to share your knowledge. I ended up building a puller and pulling the yokes. Was not too bad and now I can clean up the parts and put it all back together. At this stage can I repack the bearings without pulling everything apart?
Not sure what you removed? Are you talking about the axle yokes? Disassembly of the wheel mounting hub from the axle bearing housing is best done with the unit removed from the car and utilizing a press. Diagrams and photos on page 4-26 of the 1965 Corvair Chassis Shop Manual show how it is. Directions on this and pages around it detail servicing this assembly with some special GM tools but the tools are not necessary for off the car service. the entire yoke, hub bearing assembly is easily removed from the car as it is held by 4 nuts onto studs that are part of the suspension arm. in order to properly clearance the bearings a dial indicator is used and shims are install over remove from the stack to get the proper clearance. Here is a link to the manual should you not have one (seems like you do not). http://www.1969corvair.com/techpages/te ... Manual.pdf
The applicable portion of the shop manual — 1965 Corvair Chassis Shop Manual - SECTION 4 - REAR SUSPENSION — is attached.
:chevy:
1965 Corvair Chassis Shop Manual - SECTION 4 - REAR SUSPENSION.pdf
(3.39 MiB) Downloaded 4 times
