One Leaky Valve Cover??
Re: One Leaky Valve Cover??
joelsplace wrote:
Sat Mar 21, 2020 10:21 pm
Silicone used sparingly is great. People that goop it on have given it a bad reputation.
Permatex #2 is good also if used properly and it is actually specified in the factory service manual for some things.
I find the Permatex #2 to be excellent on valve covers where expansion rates of the aluminum head and steel cover may be a little different from each other as it stays thick gooey and pliable. Once silicone sealer dry the become slippery and solid so any variation of the sealed items expansion can make one or the other slide on the silicone and maybe cause a seep. At least this is what I think. I have seen a very large number of leaking Corvair valve covers that have silicone sealant on them, more I think than valve covers with no sealant even.
It won't slip off the surfaces are clean. It will stick to them and has the needed flex for the different expansion rates. It is difficult to get all the oil off the valve cover surface on the head so that it will stick. I put gaskets on dry.
joelsplace wrote:
Tue Mar 24, 2020 12:31 pm
I generally put good cork rubber gaskets on dry as well, but when I have a seep Issue I go to new gasket with Permatex #2
