It occurs whenever I drive over the road reflectors. It's a loud banging, on the right side only. Checked the torque arm bushing bolt is tight, the shock mounts are tight and have the rubber on each side, and replaced the 4 strut rod bushings. Any ideas?
Joe
65 Corsa Vert rear suspension banging noise
Re: 65 Corsa Vert rear suspension banging noise
Stick shift or automatic?
