KYB shocks for the '65 two door Monza
RNader
Post by RNader »
Anyone know the exact KYB part numbers for the front and rear shocks for my Monza coupe? I emailed KYB and they said that none of their shocks are indicated for Corvairs so they couldn't recommend. My loyalty and overtime money have gone to Clark's so far but I have a Amazon gift card and don't want to waste it. Thanks!
davemotohead
Re: KYB shocks for the '65 two door Monza
Post by davemotohead »
The front KYB shocks are not a direct bolt on, you need to change the lower mount, you want to use the Gas Adjust on the rear and the Excel-G on the front, Ca Corvairs sells them with the lower mount already changed to become a direct bolt on.
http://californiacorvairparts.com/index ... er=product
RNader
Post by RNader »
Thanks Dave! Appreciate the info. If these are “plug and play” then I’ll get them from C.C.
RNader
Post by RNader »
Ca...
nmunn
Post by nmunn »
Thanks!
erco
Post by erco »
What's all this twaddle that all Clark's front shocks need additional bushings for $24?
The bottoming bumper is the lower rubber on the top shock mount on LMs. It is huge compared to a regular shock mount and doesn't come with any shocks I know of. Sometimes you have to grind the bead down on the shock rod to get it to fit the hole in the bottoming bumper.
Here's a pic and diagram of the twaddle. ::-):
corvair stuff 359.jpg (93.12 KiB) Viewed 78 times
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
erco
Post by erco »
Great, there goes more beer money!
Not sure if I even have those now. I replaced my shocks some 30 years ago... back when PepBoys and Trak Auto stocked Corvair parts!
