summer/winter plate missing
hugofant
Post by hugofant »
Hi,
on my 63 turbo the summer winter plate is missing on the left side. On the right side there's only a 14x8cm tin screwed down (with a sticker on it).
Is this really as it should be? On "California Corvairs" if found a pictures were it looks a bit more "complex".
...and at "Clarks" the part is not available and also not picture (part# CU3439).
best regards
Roman
64powerglide
Re: summer/winter plate missing
Post by 64powerglide »
I have owned 3 Corvair's in my 74 years. First was a new 62 Monza 102 HP 4 speed, no summer/winter plates. Second was a new 65 4 door 95 HP 3 speed, no summer/winter plates. Third is my 64 Monza coupe 110 HP powerglide, no summer/winter plates. None of them even had factory screw holes for plates. I have lived in Kalamazoo Mi. my whole life & know those cars were bought in Michigan. Never could figure out why those summer/winter plates were there in some cars. They all had a fixed openings & no matter the weather they were putting out heat within 5 minutes of starting in the winter. I can start my 64, back it out of the garage get out & close the garage door get back in & feel heat from the heater with no winter plates. Sounds like they were just a waste of time!!!!!
hugofant
Post by hugofant »
hmmm, decals says to remove for winter operation - so fix openings would mean, that they are in a permanent winter mode and also the risk for overheating in summer....or am i completely wrong now?
br
Roman
64powerglide
There is no risk for overheating in summer, it's another vent to increase air flow. Especially if a thermostat fails & the damper door doesn't open.
hugofant
Post by hugofant »
Hi again,
are you sure about that...because discussion here says the holes should be closed to avoid overheating
br
Roman
64powerglide
I suppose if a little air were to be sucked in by the fan it could make a difference but I don't think it would be enough to make the engine overheat. Guess we need more opinions. If it were to be a problem then why did GM make some vents fixed like mine.
jcannon44
Post by jcannon44 »
I’m not sure those are stock GM, never seen any that look like that.
Jeff Cannon, Smithfield, VA
1966 Corvair Monza Conv.
Jeff Cannon, Smithfield VA
1966 Corvair Monza Convertible
perfectreign
Post by perfectreign »
Sorry for the noob response - what is a summer/winter plate? I googled and see some pictures but no description of what this is.
Kai Ponte - www.perfectreign.com
Image2006 Chevy Avalanche WBH LS
Image 2016 Chevy Malibu Hybrid
perfectreign wrote: Wed Feb 07, 2018 4:27 pm Sorry for the noob response - what is a summer/winter plate? I googled and see some pictures but no description of what this is.
Parts used on Late model engines see Clark's catalog page 104 at the bottom of the page for photos and description. They mount below the oil cooler on top of the thermostat door unit (covering the opening there) and on some cars on the same location on the right thermostat door unit as well
