speedometer reading too fast
what causes the speedometer to read faster than you are going? when driving about 30-35 mph the speedometer reads 90-100, its also kinda noisy.
Re: speedometer reading too fast
It could be a number of problems, but if the error is constant the most likely cause is a speedometer input bushing that is worn out allowing the magnet to get too close to the to the needle cup. If the speedometer part the cable fits into can be wobbled around then the bushing is worn out.
Welcome to the Corvair Forum!
You did not mention the Corvair model year or model. Several designs have been installed in Corvairs during the ten year production.
I have attached an article extracted from the CORSA Communiqué magazine regarding 1965-66 Corsa Speedometer Overhaul (CORSA Communiqué May 2012). It describes some speedometer principles of operation so the article may be useful to you.
I would like to encourage you to restart and expand on your earlier post and tell us more about yourself, as well as about your Corvair. If you can provide your personal assessment of your mechanical skills and abilities, that would help a lot. Members of the Corvair Forum love to be helpful in assisting other Corvair owners with technical support and advice, but it helps a lot if we have some understanding of your technical background and mechanical abilities, your Corvair-related knowledge, etc. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Knowing your specific location is also useful, because knowing where you live can sometimes suggest possibilities.
viewtopic.php?f=225&t=6007
The CORSA article is for the Spyder or Corsa speedometer with the "trip odometer". The Monza speedometers are not as complicated.
At one time parts were common, but now most speedometer shops do not have parts. Even after a repair the unit must be magnetized to make it accurate.
I've done a few and it convinced me not to do them for a fee - very labor intensive to get them right.
There are still some good used units out there, but you have to lubricate them to ensure they will last. I usually re-lube the bushing by setting the end of the speedometer where the cable go in in a cup of DEXRON ATF (automatic transmission fluid) for couple of days and turn the input every six hours. It will free up and lube the bushing.
The only other option is a complete teardown and rebuild. Clark's did sell rebuilts at one time.
