1964 95hp donor parts in 110hp engine
I bought a 1964 110 hp engine in pieces. I have an opportunity to buy a 1964 95 hp engine for donor parts. What parts are interchangeable? Is it ther same with different Cam and Heads? Any thoughts would be appreciated.
Re: 1964 95hp donor parts in 110hp engine
The cylinder heads are different with the low horsepower engine having a cylinder head combustion chamber volume that produces an 8.0:1 compression ratio. The 110 hp engine heads have a combustion chamber volume that produces a 9.0:1 compression ratio. Both engines use the same crankshaft, engine cases, pistons and connecting rods to produce 164 CI displacement. The 110 hp and 150 hp engines are fitted with a harmonic balancer to protect the crankshaft from developing stress fractures or cracks. As an economy move, the low 95 hp engine only received a solid cast crankshaft pulley instead of a harmonic balancer. The distributor timing and advance curves were different. Both the 95 hp and 110 hp engines had the same single muffler exhaust, and I believe that the carburetors and air cleaner assembly/PCV systems were the same. The oil cooler was larger on the 110 hp engine.
I have attached a copy of the 1964 Chevrolet Corvair GM Heritage Center Specs publication, which provides details of the engine specifications.
(1965 and later fans had a larger center hole, using a different bearing hub assembly)
viewtopic.php?f=225&t=6007
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 1 - General Information.pdf
- (108.07 KiB) Downloaded 12 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 2 - General Lubrication.pdf
- (134.91 KiB) Downloaded 10 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 3 - Suspension.pdf
- (564.64 KiB) Downloaded 12 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 4 - Steering.pdf
- (332.76 KiB) Downloaded 11 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 5 - Brakes.pdf
- (933 KiB) Downloaded 9 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6 - Power Train.pdf
- (32.63 KiB) Downloaded 15 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6a - Engine.pdf
- (1.6 MiB) Downloaded 14 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6b - Clutch.pdf
- (256.53 KiB) Downloaded 9 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6c - Rear Axle.pdf
- (661.15 KiB) Downloaded 12 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6d - Manual 3 and 4-Speed Transmission.pdf
- (194.42 KiB) Downloaded 13 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6e - Automatic Transmission.pdf
- (538.95 KiB) Downloaded 10 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 7 - Engine Tune-Up.pdf
- (931.65 KiB) Downloaded 12 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 8 - Electrical Systems.pdf
- (1.95 MiB) Downloaded 14 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 9 - Fuel & Exhaust Systems.pdf
- (3.99 MiB) Downloaded 10 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 10 - Body.pdf
- (3.91 MiB) Downloaded 12 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 11 - Accessories (Adds AC).pdf
- (4.01 MiB) Downloaded 14 times
Wow,
Thanks a lot. This is exactly what I needed and some.
