Cam shaft
Cam shaft
I have a corvair cam and don't know what engine it came out of. The engine is supposed to be 110 HP. The intake lobe has a lift of 2.05 and the exhaust is 2.30. Any ideas? TOM
- davemotohead
Re: Cam shaft
There will be a number on the cam shaft if its stock, like 889,891,304, if its a after market cam there should be a stamping on the gear end.
Re: Cam shaft
The stamping on the cam is GM5, and 383-9389. Would this cam be a 110 HP? TOM
- davemotohead
Re: Cam shaft
last 3 numbers are most likely 889 not 389
Re: Cam shaft
Dave, if is 889, would that be a 110 HP cam?
Re: Cam shaft
889
should be 60-69 80,84,& 95 HP engines.
Re: Cam shaft
What are the numbers cast into the ends of the cylinder heads? That's another big piece of the engine I.D. puzzle.
Re: Cam shaft
I think Mr. terribleted may be right. the heads and block are at the machine shop so no way to check at this time. I think to be on the safe side, I'm going to put a new cam in the engine . Thanks for all the help. TOM
Re: Cam shaft
Before you order a camshaft it will be vairy important to know what heads you are getting refurbished.tom becker wrote: ↑Sun Jan 14, 2018 7:33 am I think Mr. terribleted may be right. the heads and block are at the machine shop so no way to check at this time. I think to be on the safe side, I'm going to put a new cam in the engine . Thanks for all the help. TOM
