crack in fan housing cover
jcannon44
Unread post by jcannon44 » Thu Dec 07, 2017 9:29 am
Is this serious? do I need to replace? any advice would be greatly appreciated!!
Jeff Cannon, Smithfield VA
1966 Corvair Monza Convertible
Re: crack in fan housing cover
Unread post by 66vairguy » Thu Dec 07, 2017 10:20 am
That might be a casting "wrinkle", not unusual. The only way to tell is to look at the other side to see if it is a fracture that goes through the material.
Just my 2 cents.
Unread post by azdave » Thu Dec 07, 2017 11:04 am
I don't believe it is a crack either. If you aren't pulling the cover, don't do it just to check the backside. Take some sandpaper and smooth out the ridge and then see if you can still detect a crack or not. Bell housing often have those ridges like that too. They cause many false alarms.
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
jcannon44
Unread post by jcannon44 » Thu Dec 07, 2017 12:29 pm
Great! Thank you!!
