Distributor vacuum and hose
Jeff+Carrie'63
Unread post by Jeff+Carrie'63 » Mon Nov 27, 2017 9:40 am
New Corvair owner and have yet another question.
I have a 1963 Corvair Monza 900 - automatic.
I noticed yesterday after a drive with my wife that the gas mileage was noticeably low. Or, at least low in my estimation.
In checking under the hood I see that the vacuum hose from the Distributor vacuum is collapsed somewhat.
The hose seems to be too thin in my estimation for what it is intended. It is a clear hose, which most photos I see show the standard blue hose is used.
Does anyone know if that could be the problem?? And if so, can I just use standard (looks like 3/8") hose to replace this?
Thanks.
Jeff
Re: Distributor vacuum and hose
Unread post by Jerry Whitt » Mon Nov 27, 2017 11:39 am
The clear hose is the wrong type. Probably stolen from a fish tank. Your local parts house will have the proper size hose.
Just take the car over and show them what you need.
When the hose collapses, the vacuum advance does not allow the timing to advance, which will then cause lack of power and lower gas mileage.
Unread post by bbodie52 » Mon Nov 27, 2017 12:15 pm
The vacuum advance tubing/hose would be the same material and diameter as the short hose that connects between the base horizontal vacuum port on each carburetor and the choke vacuum break diaphragm that is illustrated in the diagram below. Common colors are black or blue, and it may be made of rubber or silicon rubber. The correct hose type is listed in the Clark's Corvair Parts catalog, but you should be able to find a suitable hose at almost any auto parts store. Just tell them it is for your vacuum advance connection between the distributor and the carburetor. Clear plastic tubing is not suitable, and as it gets warm the walls of the tubing soften and would tend to collapse.
Part number C477: HOSE-VACUUM
Weight: 0 lbs 10 oz
Catalog Pages(s): 78
Price: $ 4.80
This diagram illustrates potential problem areas for a normally aspirated Corvair where vacuum leaks can occur.
:dontknow: I would like to encourage you to expand on your earlier posts and tell us more about yourself. If you can describe your personal assessment of your mechanical skills and abilities, that would help a lot. Members of the Corvair Forum love to be helpful in assisting other Corvair owners with technical support and advice, but it helps a lot if we have some understanding of your technical background and mechanical abilities, Corvair-related knowledge, etc. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Knowing your specific location is also useful, because knowing where you live can sometimes suggest possibilities.
:welcome:
Jeff+Carrie'63
Unread post by Jeff+Carrie'63 » Mon Nov 27, 2017 12:34 pm
Jerry...Brad...thanks so much for the assistance on this. On a scale of 1 to 10, my mechanical skills are probably a 5. But, since purchasing my Corvair three weeks ago, I have really been reading and learning a lot about the car I now have. My skills will increase as times goes along. I enjoy learning and doing, so all of this information really helps me.
Thanks again!
Jeff
chris
Unread post by chris » Thu Nov 30, 2017 9:00 pm
The nice thing about the vacuum hose is that it’s super easy to replace.
