1965 E-Brake Tail End Assembly?
GasDaddy140
Unread post by GasDaddy140 » Mon Nov 06, 2017 10:47 am
Hey Corvairs!
I'm looking for a little help with a picture or diagram of how the E-Brake cable assembly lands at the end of the tunnel. This is where it secures and connects to the curved puller to pull the cable brake line bow coming from the rear drums. I have a collection of weird parts and as usual don't know how to use them!
Thanks for your help.
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Re: 1965 E-Brake Tail End Assembly?
Unread post by bbodie52 » Mon Nov 06, 2017 11:38 am
Left Click once or twice to enlarge for better viewing...
1965 Corvair Emergency Brake Cable Detail (Rear)
Parking brake cable details are illustrated beginning on page 8 of the attached 1965 Corvair Assembly Manual - BRAKES
Parking brake adjustment is described starting on page 5-6 of the attached 1965 Corvair Chassis Shop Manual - SECTION 5 - BRAKES.
The link below will provide you with a list of useful websites that are Corvair-related. Some of the links will lead you to an extensive technical library that will allow you to download shop manuals and other technical references in Adobe Reader (.pdf) format at no cost.
:link: http://www.corvairforum.com/forum/viewt ... 225&t=6007
:chevy:
1965 Corvair Assembly Manual - BRAKES.pdf
(2.29 MiB) Downloaded 3 times
1965 Corvair Chassis Shop Manual - SECTION 5 - BRAKES.pdf
(4.6 MiB) Downloaded 3 times
GasDaddy140
Unread post by GasDaddy140 » Mon Nov 06, 2017 2:16 pm
Thanks BBodies52!
I have those diagrams. What I don't see is the where the front cable assembly cable goes thru the frame grommet with the small hole to lead to the curved puller. Does the cable simply push thru?
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Unread post by terribleted » Mon Nov 06, 2017 4:49 pm
The cable simply exits the tunnel thru the grommet. A split grommet is used generally. Remove grommet, put cable thru rear tunnel hole and then re-install grommet.
GasDaddy140
Unread post by GasDaddy140 » Tue Nov 07, 2017 10:15 am
Thanks TerribleTed-
Yes-I crawled underneath my Corsa and figured that little gromet out! :tu:
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
