Are the original exhaust manifold gaskets made of asbestos?
I've dropped one of the exhaust manifolds and the old gaskets are white. I'm assuming they're made of asbestos. Is this correct?
Re: Are the original exhaust manifold gaskets made of asbestos?
Could be.
I just removed mine a few days ago and my first thought was asbestos. I wasn't sure so I treated it as such. I soaked it with water to keep from making dust. Be safe.
I'm pretty sure they are, but I can't say 100%
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
64 Monza Convertible
Gouldsboro, PA
66 Corsa 140 coupe
Thanks!! I used your idea and wet them down. Two gaskets came off intact. Two came off almost intact. And, two broke into pieces. Keeping them wet helped.
If you really want to know, there are laboratory asbestos test kits where you can mail in your sample for analysis...
https://www.amazon.com/s/?ie=UTF8&keywo ... 1avpb7cn_e
The simple answer is that if you live in California it has a substance that is known to cause cancer. Everywhere else it is perfectly fine. Lol
- UltraVan345
Best guess is the originals were. I was just putting some parts away. Fel-Pro Exhaust manifold and pipe gaskets said they were an asbestos replacement material. I can't tell you when these were made. From the looks of some of the other items with them I would say mid 80's or later.
