Transmission question
jcannon44
Post by jcannon44 »
I’m restoring a 1966 corvair Monza. Power Glide 2 speed. Took transmission pan off today because of leaking gasket. While removing gasket i thought I heard something fall out of transmission area, but i cant find anything on ground. Could one of you smart guys take a look at my photo and see if you can see anything that may have fallen off, Thank You! Btw where does the O-ring attach for the filter I removed? Any gasket for dip stick tube on side of pan?
Jeff Cannon, Smithfield VA
1966 Corvair Monza Convertible
Re: Transmission question
Did you remove the oil pickup and screw? The picture may help with the o-ring placement...
You may find some useful reference material at this link...
CORVAIR POWERGLIDE AUTOMATIC TRANSMISSION SERVICE GUIDE
:link: viewtopic.php?f=225&t=5760
jcannon44
Post by jcannon44 »
bbodie52 wrote:Did you remove the oil pickup and screw? The picture may help with the o-ring placement...
Thank you for this info! By oil pickup, do you mean the filter?
funvairs
Post by funvairs »
The oil pickup is the screen filter. There is no gasket or o-ring on the dipstick tube
Chris Brown
Member
CORSA
jcannon44
Post by jcannon44 »
funvairs wrote:The oil pickup is the screen filter. There is no gasket or o-ring on the dipstick tube
Perfect! Thank You!
