140 carbs
skipvair
140 carbs
Post by skipvair »
I have recently gotten a 66 Corsa with a September 65 build date. The car is a great restoration, but I note it has 65 carb linkage on it. Is it possible some early 66 models had this or is it just incorrect?
Frank Metasavage
66 Corsa 140 4 speed Stock
Re: 140 carbs
As far as I know, the 65 140 linkage design ended while 65's were still in production. The 66-style linkage can be found on late 65's.
Below from cnicol post in 2012
Early 65: Secondary rods have no spring & cross shaft secondary lever has a long, curved slot.
Late 65-67: Secondary rods each have an exposed, concentric spring. Cross shaft secondary lever has a single hole for rod, (no curved slot). System includes choke-based secondary lock-out.
68-9: Secondary rods each have a concentric spring hidden inside a tube. Cross shaft secondary lever has a single hole for rod, (no curved slot). System includes choke-based secondary lock-out.
Re: 140 carbs
The 66 lock-out linkage has been troublesome overall. Things must be just adjusted just right and in good repair (not worn) to function properly. Many people over the years have given up on their 66 linkage setup and swapped in the 65 direct non lock-out linkage. I personally would stay with the 65 linkage. I have found it to be essentially trouble free compared to the lock-out setups. When you accelerate to the point of the secondarys opening they open every time. the only issue is that if you open the secondarys with the engine cold a stumble can sometimes result. I had to use a 66 linkage, first I would have to have a very good set of parts and second I would install new chokes before I would try to use it. The chokes must function evenly and have strong pull down in order for everything to function as it should.
skipvair
Re: 140 carbs
Post by skipvair »
Thanks. They are staying!
Frank Metasavage
skipvair
Re: 140 carbs
Post by skipvair »
I found these are 66 carbs with 66 linkage. The lockouts work on all 4 in this manner. I am removing the lockouts. BTW, I didn't have much trouble with previous car 66 linkage.
Frank Metasavage
skipvair
Re: 140 carbs
Post by skipvair »
Another question. Do secondaries on 65 linkage rely on gravity to return them to closed? One was sticking when I re activated them. (They were previously adjusted not to work at all).
Frank Metasavage
skipvair
Re: 140 carbs
Post by skipvair »
Btw. This car has 65 linkage. I also have a 66 set of carbs with linkage and a 68-9 set of linkages and engines.
Frank Metasavage
Re: 140 carbs
None rely on gravity. The spring under the accelerator pump should return the throttle to closed when released by the linkage.
skipvair
Re: 140 carbs
Post by skipvair »
Secondaries don't have accelerator pumps if I am correct. it seems to be just the weight of the linkage that closes them unless there is perhaps a spring where the accelerator pump is in the primaries. I haven't taken them apart yet, but it seems something positive should shut them down, and there is very little if anything to shut the butterflies on mine. They run fine, but until I lubed them up pretty well after a long period of inactivity, they would stick at WOT.
Maybe it's time to take the tops off.and see what gives on the secondaries.
Frank Metasavage
Re: 140 carbs
The accelerator pump units are in the secondarys as well as the primarys. They do not use the rubber seal that makes them pump (so they do not actually pump). The rest of the parts are the same as in the primarys. The theya re the unit with the spring and sliding deal on them. They have a spring under them just like the primarys do. The spring under the secondary "pumps" is shorter than the one under the primary pumps. This spring is what returns the carb to close throttle along with of course the throttle linkage itself. If the springs are not under the pump unit the throttle plates may not fully close when the linkage is not operating the secondary carbs
Trip
Re: 140 carbs
Post by Trip »
I switched my 66' Corsa 140 to 65 linkage myself, pretty common swap. Just make sure you floor the accelerator once every time you drive the car to keep the secondary throttles from getting stuck. =D
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
64 Monza Convertible
Re: 140 carbs
Grymm wrote: Wed Oct 18, 2017 7:05 pm
This is key to avoiding most issues people have with their secondarys
gnrand
Re: 140 carbs
Post by gnrand »
I replaced my 68 140 linkage with Roger Parent's 65 linkage and disabled the secondary stops. I found that getting the pivot rods adjusted to be a little difficult.
Jeff
1965 140 Corsa
1965 Corsa Convertible
1966 Crown V8 383 435hp
1986 Buick GN V6 600hp
Re: 140 carbs
gnrand wrote: Thu Oct 19, 2017 6:20 am I replaced my 68 140 linkage with Roger Parent's 65 linkage and disabled the secondary stops. I found that getting the pivot rods adjusted to be a little difficult.
Jeff
Rogers linkage is top drawer. On the set I installed it did take a little trial and error to get the secondary link rods perfectly synched, but, well worth the effort.
Trip
Re: 140 carbs
Post by Trip »
terribleted wrote: Thu Oct 19, 2017 8:00 am Rogers linkage is top drawer. On the set I installed it did take a little trial and error to get the secondary link rods perfectly synched, but, well worth the effort.
Yes, I wanted a set myself but I'm one of those "cheap" Corvair guys. :rolling:
Gouldsboro, PA
66 Corsa 140 coupe
skipvair
Re: 140 carbs
Post by skipvair »
terribleted wrote:None rely on gravity. The spring under the accelerator pump should return the throttle to closed when released by the linkage.
Replying to an old post of my own with what I found out about secondary return. The carbs were from a place in Florida. The wrong return springs were installed. Ordered correct ones from Clarks and problem was solved.
Frank Metasavage
