Carpet installation
firstgencamarojunkie
Carpet installation
Post by firstgencamarojunkie »
I'm putting new carpet in my car / I always seem to have a problem cutting out the holes for the seat bolts, seat belt bolts, etc. I end up hacking at the carpet with a xacto knife - and - the result is usually pretty ugly. So - any suggestions on how to measure, cut and fit these holes? I'm sure someone out there has a ingenious solution that I'm not thinking of - thanks - Andy
64powerglide
Re: Carpet installation
Post by 64powerglide »
I just use a good size awl.
I start with a large awl, poke a hole and then carefully enlarge it with a good pair of fiskars original orange handled scissors. I use a utility knife with a fresh blade (or blades) to remove unnecessary backing and to cut large holes (shifter for example).
funvairs
Post by funvairs »
Use an awl to start the hole, then use a hot punch to get the hole to the correct size.
Chris Brown
Member
CORSA
recessbilly
Post by recessbilly »
I leave the seat belt bolts in the holes and after I set the carpet, I cut the bolts out.
Trip
Post by Trip »
recessbilly wrote: Sat Oct 14, 2017 9:21 pm I leave the seat belt bolts in the holes and after I set the carpet, I cut the bolts out.
This is my preferred method as well. :tu:
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
64 Monza Convertible
