Trans seal
naderwaswrong
Trans seal
Unread post by naderwaswrong » Sun Oct 08, 2017 11:45 am
Leaking from the very end of the trans where the shift rod goes in. What is that seal called? If I was looking at the right parts, I saw one called a repair seal. Is it a seal that could get you by for now? Thanks again.
Re: Trans seal
Unread post by terribleted » Sun Oct 08, 2017 12:10 pm
Shift selector shaft seal Clark's P/N C497 page 129 of catalog
naderwaswrong
Re: Trans seal
Unread post by naderwaswrong » Sun Oct 08, 2017 1:14 pm
Thank you.
lostboy
Re: Trans seal
Unread post by lostboy » Mon Oct 09, 2017 11:59 am
I replaced mine several times and it still leaks. I'm going to have to assume that the shaft itself is imperfect of something to that effect. Anyway, if it still leaks after you change it don't feel too bad.
-Steve
