Rear suspension
naderwaswrong
Rear suspension
Unread post by naderwaswrong » Tue Sep 26, 2017 9:04 am
I noticed that the 63 and 64 have different rear suspensions. Is the 64 with the transverse leaf spring an improvement over the 63? Is the leaf the only difference? Thanks.
Re: Rear suspension
Unread post by terribleted » Tue Sep 26, 2017 9:28 am
It is an improvement decreasing body roll and lessening tendency for rollover during extreme maneuvers. The leaf spring is not the only difference. The rear lower suspension arms are drilled to accommodate the outer leaf spring mounts. The 64 only differential case is a different casting including a mounting boss for the center of the leaf spring.
OH additionally the coil springs are different.
Re: Rear suspension
Unread post by bbodie52 » Tue Sep 26, 2017 10:53 am
:goodpost:
In addition to the above improvements, the coil spring rate was changed to match the new rear suspension design that incorporated the rear transverse leaf spring.
On the front end, the front stabilizer bar that was previously only seen on 1962-63 turbocharged Spyders and was a heavy duty suspension option on other Corvairs from those years became standard on all 1954 an later Corvairs.
Also in 1964, engine displacemnt was increased from 145 CI to 164 CI by increasing the crankshaft stoke. The stamped steel riveted crankshaft pulley was replaced by a cast iron pulley on 95 hp engines and by a harmonic balancer on all engines rated at 110 hp or higher. The heavy steel fan was replaced by a lightweight cast magnesium fan and associated belt guides to improve fan belt reliability.. The air cleaner design on most passenger cars was revised. The Positive Crankcase Ventilation (PCV) system that was introduced in 1963 was revised n most passenger cars to utilize a fixed vacuum oriface intead of the PCV valve. .
naderwaswrong
Re: Rear suspension
Unread post by naderwaswrong » Sun Oct 08, 2017 7:09 pm
Is this a 64 transaxle?
Re: Rear suspension
Unread post by bbodie52 » Sun Oct 08, 2017 8:02 pm
1964 Corvair Transverse Leaf Spring (Suspension component attaches to the differential in the center)
Re: Rear suspension
Unread post by terribleted » Sun Oct 08, 2017 8:15 pm
Yes that is a 64 differential. You need the 64 coil springs and all the parts for the transverse leaf setup to complete it.
naderwaswrong
Re: Rear suspension
Unread post by naderwaswrong » Mon Oct 09, 2017 4:00 am
I've got the complete set-up minus the center bracket and some rubber parts which need replacing.
So I have a 63 with a 66 engine, a 64 transaxle and transmission, and a 60 front emblem.
Total FrankenVair. :woo:
Re: Rear suspension
Unread post by terribleted » Mon Oct 09, 2017 11:04 am
I would not say Total Frankenvair. I have seen much more mixed up that that:) Besides you have a good combination of parts...better than 63 rear suspension and engine!
Trip
Re: Rear suspension
Unread post by Trip » Wed Oct 11, 2017 10:34 pm
Put some 63 tail lights on, 63 tail lights are best tail lights! =D
Just to clarify, all I'm actually saying is I personally love the look of 63 tail light lenses. Oh, and the 63 glove box/radio/dash trim is my favorite pattern. I'd say 63 is just straight up my favorite EM interior.
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
65 Corsa 180 coupe
64 Monza Convertible
61 Air conditioned Monza coupe (Missy's car)
