Installing rubber schroud seal around engine
AZScott
Unread post by AZScott » Fri Sep 22, 2017 8:50 am
I am in the process of installing the rubber strips that go around the engine to attach to the top engine shroud to the engine compartment. I am using new rubber strips and new Clark staples. Would appreciate any advise or recommendations from the forum to help me in this process. I am installing this on a ’64. My thought was to use weather strip adhesive to attach the bottom metal strips to the rubber , then drill the rubber where the stables go through. However not sure this is the best way, so appreciate any tricks other members have used that work. If this is already posted somewhere please point me to where it is. Thank you.
63 Monza Coupe (164-4 carb)
64 Spyder Convertable
62 MGA Roadster
74 Norton Commando
69 Triumph Bonneville
64powerglide
Re: Installing rubber schroud seal around engine
Unread post by 64powerglide » Fri Sep 22, 2017 9:19 am
Here is a video thanks to Davemotohead1.
AZScott
Unread post by AZScott » Fri Sep 22, 2017 11:10 am
Thanks 64powerglide, just what I was looking for.
62 MGA Roadster
74 Norton Commando
jimrob
Unread post by jimrob » Mon Oct 16, 2017 4:19 pm
I didn't use staples. A lot of trouble. I used aluminum pop rivets instead.
