I was just looking inside the exhaust chambers for my 1964 110 hp head and it looks like a kink in the exhaust side! Has anyone ever milled that groove off down near to the guides because I don't know how the exhaust can get through there? It's like a 90 degree turn.
Exhaust Valve Questions
Re: Exhaust Valve Questions
Typically I will use use cutters on a die grinder and do a bowl blend as well as taper the area around the guide down. The flow picks up significantly when you do that.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Have you ever ground it down all the way to just enough material for the guide?
