Crane EI
- 66corsaguy
Crane EI
DOes anyone know if Crane changed its name to FAST. I bought Crane ignition on AMAZON and it comes in as FAST
Is it the same? Did I buy the correct one for my 66 Corsa? I also got the ps20 coil which is labeled FAST
do I have to use the ballast? I have a brand new clarks harness and not modified. the cloth wire is the resistor wire? It loops in a circle.
I think my coil has failed or the pertronix cos I am unable to turn the car over it stalled a bunch prior. Backfired prior. and now is just rrrr rrrrr rrrrr rrrrr. Tried a jump. Nada. I have gen light and fuel gage. so thinking it's coil. Don't know it's age. How long they last I read is anyone guess!
I'm going to attempt install tonight I hear this EI is solid but I hope I have the correct version and not some knockoff???
Re: Crane EI
Interesting. Big suppliers calling FAST the replacement and the Crane unit un-available. The parts look the same. P/N is same so perhaps it has the same parts and should be correct for application.
- 66corsaguy
Re: Crane EI
Hmmm. Interesting.terribleted wrote:Interesting. Big suppliers calling FAST the replacement and the Crane unit in-available. The parts look the same. P/N is same so perhaps it has the same parts and should be correct for application.
Re: Crane EI
Oh yeah The Crane XR700 connects directly to the stock ballast (ignition wire) in the harness with no mods. Read the directions on the FAST to be sure it uses the ballast wire.
Re: Crane EI
Fast bought Crane's ignition products and technology.
I have the same "Crane" unit on my turbo Corsa - bought from Clarks. It requires the ballast do not run straight 12v. Get the documentation from here: http://www.cranecams.com/uploads/instru ... -0700_.pdf
Do not push the shutter all the way down - it will rub the point plate.
Alec
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
Dahlonega, GA
Re: Crane EI
Why not call Crane Cams Technical Support directly and ask them to confirm if their brand name/marketing/production labeling has changed. You can also ask them about the requirement for a ballast resistor to reduce the input power voltage supply feed for the electronic module.
The system used to be marketed as the ALLISON XR700 until Crane bought Allison. To add to the confusion factor is that Crane Cams also offers the XR3000, which appears to be an updated XR700 design that no longer demands the use of a factory ballast resistor, but instead runs on a full 12 VDC -- requiring the removal of the ballast resistor or resistor wire from the ignition primary circuit. The marketing price and operational/functional use for the XR3000 seems to be the same as (or similar to) the XR700. Can the XR700 and XR3000 be used interchangably?
XR3000
For increased spark energy (over 150% greater spark gap energy over stock points ignition) and maintenance-free operation the XR3000 is the answer. It’s a high performance version of the XR700. It incorporates surface-mount technology for reduced size and greater reliability, and internal components are sealed in urethane for protection from dirt, moisture and vibration. An optical trigger is included in the easy-to-install package. Available for most domestic and import 4, 6 and 8-cylinder applications. Use with canister or E-Core coils.
http://www.cranecams.com/view.php?s_id=17GETTING THE RIGHT POINTS REPLACEMENT
• Call toll-free 866-388-5120 and get personalized assistance from one of our experienced technicians. The tech line hours are: Monday thru Friday 8 AM to 5 PM (Eastern).
Re: Crane EI
Fast press release:
FAST Unveils New Ignition Division
Memphis, TN – FAST is launching a full line of ignition systems and related components for both race and street applications to strengthen its position as the leader in fuel, air and spark technology.
For more than two decades FAST has been at the forefront of the performance aftermarket with its state-of-the-art fuel injection systems, manifolds, throttle bodies and more. Now the COMP Performance Group brand has entered the ignition market with its purchase of Crane Cams’ ignition products and technology.
FAST customers will have a wide variety of products to choose from for drag, oval track, road racing and street performance use. Parts include the full line of previously Crane-branded components, along with new products developed by the FAST engineering staff, including the E7 CD Ignition Controller. Each component is designed and developed using cutting-edge technology, and then painstakingly tested both in the lab and on the track. All FAST parts are also backed by unmatched technical assistance that lets customers stay ahead of the competition. FAST ignition systems and components such as coils, distributors, crank triggers and spark plug wires can be found in the new 2016 Ignition Catalog and on the FAST website.
Alec Carlson
Dahlonega, GA
Dahlonega, GA
- 66corsaguy
Re: Crane EI
Hey Alec. I'm installing the shutter and lens did you have brackets that fit perfectly or did you have to make something? None of the brackets supplied are working with my holes.acarlson wrote:Fast bought Crane's ignition products and technology.
Alec
I did push it all the way down but had a feeling it was too low cos it won't center on the lens
I'm getting a little frustrated cos I'm wondering if they left some parts out.
In paticular this:
If I had that I'm sure it would fit since it looks highly adjustable.
Re: Crane EI
Crane was sold some years back. Some of the product lines were sold off to other companies. Their ignition products were nice but slow sellers. FAST (Fuel Air Spark Technology) is a big player in stand alone efi systems and components that is owned by the same group that owns Comp Cams/TCI/Zex/RHS/Inglese
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Re: Crane EI
I'll pull the distributor cap off later this morning and post a picture.66corsaguy wrote: ↑Wed Aug 23, 2017 7:07 pm Hey Alec. I'm installing the shutter and lens did you have brackets that fit perfectly or did you have to make something? None of the brackets supplied are working with my holes.
Alec
Alec Carlson
Dahlonega, GA
Dahlonega, GA
Re: Crane EI
Here is a link to the FAST (Fuel Air Spark Technology) website...
http://www.fuelairspark.com/
IGNITION & COMPONENTS
http://www.fuelairspark.com/fas/ignitio ... onentshtml
Does FAST® offer a points replacement kit?
You bet! For muscle cars and early rods, we offer a compact kit called the XR-i. This device mounts in place of the points assembly and triggers the ignition from the original lobes for simple installation and solution. For other applications such as vintage racing, we offer two higher output systems, the XR-700 and XR-3000. We even have an optical trigger kit to use with an E6 ignition. See pages 16-18 for more information.
- FAST Ignition - 2017.pdf
- (4.01 MiB) Downloaded 13 times
- FAST-2016-Catalog.pdf
- FAST-2016-Catalog
- (13.25 MiB) Downloaded 14 times
Re: Crane EI
Unless they changed it somehow this is not the bracket you would use. The bracket is likely flat with a pin on one end of the under side and a screw hole on the other (just like the bottom of the points) The bracket has on upright tab in the near middle that the optical pickup screws too. Perhaps the P/N 226 does not include what you need...there have always been multiple P/N's for these with varied brackets in each. Call the manufacturer to make sure what you need is in your kit before spending a lot of time trying to make improper parts work.66corsaguy wrote: ↑Wed Aug 23, 2017 7:07 pmHey Alec. I'm installing the shutter and lens did you have brackets that fit perfectly or did you have to make something? None of the brackets supplied are working with my holes.acarlson wrote:Fast bought Crane's ignition products and technology.
Alec
In paticular this:
Re: Crane EI
Here is a top-down view - you can see the pin on the left side of the bracket:
I got 5 different types of brackets with my 700. It took some experimentation to figure out which one to use on my engine...
Alec
Here is a side view. You can see where the shutter is positioned and the bracket screw on the right side:
Here is another side view:
This is the resistor you should have gotten with the XR-700. Pay no attention to where it is mounted. I'm using it on my engine stand. You should not need it with the stock Vair engine harness.
Here is the picture from the XR-700 documentation. Use the Mallory YL bracket (L-shaped, pin on one side, screw hole on the other):
The bracket goes where points were mounted. Use the points screw to mount it.I got 5 different types of brackets with my 700. It took some experimentation to figure out which one to use on my engine...
Alec
Alec Carlson
Dahlonega, GA
Dahlonega, GA
Re: Crane EI
Unfortunately all the kits do not include all the available brackets. I have gotten one XR700 in the past that did not include the one needed in the Corvairs. The parts included vary by part number. I do not for sure know the P/N you need.
- 66corsaguy
Re: Crane EI
The PO used pertronix and I switched to the Crane. I used the same metal thing after looking at your original picture I realized which one you used.
So I don't have that spring tho that you have. Everything (points etc) was pulled prior. Hoping that's not important.
But I think I've got it correctly and I skipped the ceramic thing because I have a brand new engine harness with fabric resistor wire intact.
Re: Crane EI
The Crane unit is made to install to the STOCK points plate. The Pertronics replaces the stock point plate with their own unit. I am not sure the Crane parts are fully compatible with Pertronics plate.
What you have pictured there might work but hard to tell from the photo whether the optical pickup is truly where it can get the full read on the rotor slots coming by. I would re-install a stock points plate and the proper Crane brackets to work with it.
